Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 1 > Northwest
Old 08-29-2007, 07:00 PM   #1 (permalink)
The Hotness's Avatar
Member Number: 53381
Cool Oh man, what a sad day... need advice.
So the new news.
Recently, went and upped the boost on my car. I am now pushing 27lbs and holding 18-19ish.
Also, added some coolingmist meth injection (70/30) mix roughly.
Then put some 100LL in the tank, and for once my redlight stays on.
Now for the first couple nights this car went like a RAPED ape!
But now my clutch won't hold the power.
and now had to DEtune the car, what a sad day.
So, I am NEW clutch shopping!!!
Thought maybe some could give me some advice on what to buy and how well they perform.
I need something that will be rated to the 500hp range, and allow me to use the "boost hold feature" or "pop" shift, however; you may call it. I could give to craps about pedal feel.
I thinking about doing a lightened flywheel at the same time and could use some good thoughts.
Also, could someone shine some light on this "holds 170% over stock crap?" 170% * ~240hp = 408 => not enough....
-Chris
~Chris
03' SRT-4
-Stage 3 w/toys and a bunch of other crap.
Super Neon Totaled 9/6/07, now parting out
The Hotness is offline   Reply With Quote
Old 08-29-2007, 07:04 PM   #2 (permalink)
moltenice's Avatar
Member Number: 6528
Trader Rating: (24)
PTP....
ANd I think I saw you yesterday afternoon heading south on I5
moltenice is offline   Reply With Quote
Old 08-29-2007, 08:01 PM   #3 (permalink)
2004NeonSRT4's Avatar
Member Number: 4577
Trader Rating: (31)
lower the boost, blowing hot air not making any power above 23ish psi. only shortening the life of the stocker. get the cm stage iv 6puk and a ragetech clutch pivot arm
2004NeonSRT4 is offline   Reply With Quote
Old 08-29-2007, 08:07 PM   #4 (permalink)
Supermario's Avatar
Member Number: 43853
X2 Lower youer boost. That Stg3 turbo is going to go Kerplow!. BTW, get a ACT Sprung 6 puck.. Heard they are great!
"When you can't make them see the light, make them feel the heat." ---Ronald Reagan
Supermario is offline   Reply With Quote
Old 08-29-2007, 08:12 PM   #5 (permalink)
moltenice's Avatar
Member Number: 6528
Trader Rating: (24)
I run 25psi on the S3, and Nivo ran 28 and made GOBS of horsepower. He also runs meth so cooling isnt too bad I imagine, especially with ambient temps in the 60's.
Big FMIC would help out a whole lot though, also the spike and drop is kind of extreme. How are you getting the spike that high on that WGA? I would say boost leak like a mofo, but It's probably your WGA. Or some combo of.
I spike 25 and hold 21. So 4psi drop which is what you want. Shit ideally you want 25psi spike, 25psi hold (example). I run the AGP S3 WGa though.
Old 08-30-2007, 12:23 AM   #6 (permalink)
srt4moster's Avatar
Member Number: 24528
ptp stage 3 clutch is were the money would be best spent.
srt4moster is online now   Reply With Quote
Old 08-30-2007, 02:05 PM   #7 (permalink)
Member Number: 4577
Trader Rating: (31)
oops didnt see stage 3 in the sig. carry on.
Old 08-30-2007, 08:13 PM   #8 (permalink)
ToMuchBoost's Avatar
Member Number: 35620
Trader Rating: (69)
I had a ptp stage3 for a VERY short time..................... returned it and got a CM4
Cluch Masters Stage 4, (4 puck race). Drives pretty nice and no problems holding/putting the power down.
FYC Racing
Build Thread Here
ToMuchBoost is offline   Reply With Quote
Old 09-01-2007, 12:10 AM   #9 (permalink)
Clutch Masters Stage 4 seems to be a viable option, but it claims that it hold only 170% over stock = 408hp which is not enough to suit my future needs. Or, am I reading this wrong?
Also, does anyone else get slight movement of their clutch slave cylinder?
Should I go with an aluminum flywheel?
Thanks for the helpy.
Old 09-01-2007, 12:31 AM   #10 (permalink)
Trader Rating: (69)
My guess would be that the holding power is measured in TQ not HP.
If this is right then 170% over the stock torque of: 245 would be (1.7x245 = 416.50), 416.5 + 245 = 661.50 TQ
Old 09-01-2007, 11:45 AM   #11 (permalink)
Member Number: 4577
Trader Rating: (31)
thats not how a clutch's tq holding numbers work. i dunno how they get the numbers but i think the stock clutch is rated at like 225tq or something like that. again i dont know how they get that number. but to make it easy any version of the stage 4 cm will hold 500whp any day.
Old 09-01-2007, 02:14 PM   #12 (permalink)
DJOrtiz's Avatar
Member Number: 17860
Trader Rating: (20)
i heard alot of good things about the act stage3 clutch homie...
so you fixed the over-heating problem you where having?
DJOrtiz is offline   Reply With Quote
Old 09-01-2007, 07:43 PM   #13 (permalink)
Well, I shall get to the bottom of this. I will shoot Clutch Masters an e-mail and check out their customer service.
DJ: Still haven't fixed the overheating issue, just learning to deal with it. Still waiting on proper tools to diagnois properly.
Old 09-01-2007, 07:48 PM   #14 (permalink)
DJOrtiz's Avatar
Trader Rating: (20)
weird homie... good luck with that homie...
Page generated in 0.20795 seconds with 13 queries
