Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums 1 > Northwest
Old 04-17-2008, 12:27 AM   #1 (permalink)
valeriekay_2000's Avatar
Member Number: 27795
Trader Rating: (26)
Default note to self: fuel tanks can be heavy
I drove the car around until it was empty, or so I thought...my gas light was on for a good 20-30 miles and my paranoid self didn't want to be stuck somewhere without gas.
Dropped the tank to do the fuel pump, and ya, there was about 2-3 gallons still in there. So thankfully I had an extra hand there to get the tank back up when I was done...No I didnt think about draining the gas into a canister until I had it strapped in.
I'm pretty sure I fixed that fuel issue too.
So, here was the issue. I'd be cruising along, and come up to a long hill, and while driving up it, my VAC was around 0...after getting to the top of the hill, and shifting to 5th, my wideband would go rich to the 12's, and my RPM's would hang. I'd have to do a rolling re-start, and it would go back to normal.
I tried replicating the same thing the last two days after installing the walbro, and the issue is fixed
valeriekay_2000 is offline   Reply With Quote
Old 04-17-2008, 01:00 AM   #2 (permalink)
tyeayo's Avatar
Member Number: 37734
cool.....
wanna come on the may drive???
tyeayo is online now   Reply With Quote
Old 04-17-2008, 01:40 AM   #3 (permalink)
Trader Rating: (26)
If I'm not working
Old 04-17-2008, 01:55 AM   #4 (permalink)
tyeayo's Avatar
If I'm not working
May 3rd, its a saturday...........shoudl i add you to the list
Old 04-17-2008, 02:20 AM   #5 (permalink)
The Hotness's Avatar
Member Number: 53381
I thought you could change the fuel pump without dropping the tank.. Pretty sure. Obviously too late for you, but for future reference.
~Chris
03' SRT-4
-Stage 3 w/toys and a bunch of other crap.
Super Neon Totaled 9/6/07, now parting out
The Hotness is offline   Reply With Quote
Old 04-17-2008, 02:46 AM   #6 (permalink)
Trader Rating: (26)
I had the undercoating rust proof crap on the car, and it was a biatch to get that cap off since they decided to spray it directly...
Old 04-17-2008, 03:29 AM   #7 (permalink)
Oh that's !
Old 04-17-2008, 07:36 AM   #8 (permalink)
BACARDI_DWB's Avatar
Member Number: 20780
Trader Rating: (18)
uhh you would not have been able to train the tank regardless unless you unscrewed the white canister, i found out the hard way (full tank and a broke car, so i could not drive it around to get empty) you can not cyphen the fuel, i just ended up using a jack to lower the tank and then tip it in a 5 gallon jug. PITA
TRUNGE.
BACARDI_DWB is offline   Reply With Quote
Old 04-17-2008, 07:56 AM   #9 (permalink)
Member Number: 49579
If I'm not working
hacks should not have sprayed the tank.
btw, assuming the fuel pump works at all, draining the tank is a breeze.
srtprince is offline   Reply With Quote
Old 04-17-2008, 10:49 AM   #10 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (532)
Good job on doing the work yourself and.... you may need to replace the filter as well.
Old 04-17-2008, 06:45 PM   #11 (permalink)
Trader Rating: (26)
i replaced the filter attached to the pump, it was nastay...all black and crapped up
Old 04-18-2008, 12:56 AM   #12 (permalink)
There is another one in the silver can that sits on top of the white ring that you took off. Its called a FPR but it has a filter in it as well. Its really easy to pop off and check if it needs to be replaced. PM me and I will give you the how to or call me and I will explain.
Old 04-19-2008, 04:23 PM   #13 (permalink)
Checksum's Avatar
Member Number: 19673
to drain the tank (a strip warriors best friend)
turn off the car
take the top off the fuse box, unplug the fuel pump relay
get back in the car, start it and let it die, this depressurizes the fuel system.
turn the key to off
get a gas can and remove the fuel line from the fuel rail.
put the fuel line in the gas can.
take the 10a fuse from your horn and use it to jump the fuel pump relay.
Turn the key to on and your fuel pump will drain your tank into the can.
reattach all relays, fuses, and lines.
FILL TANK WITH RACEFUEL AND PWN ON SOME V8
... or change your fuel pump
... or make a bonfire with the fuel
... or torture some cop duct-taped to a chair with no ear
choices choices choices
Checksum is online now   Reply With Quote
Old 04-19-2008, 09:49 PM   #14 (permalink)
Member Number: 47638
turn off the car
turn the key to off
im going with option c....and then option b..
Running out of bolt ons...
Lupis is offline   Reply With Quote
Old 04-20-2008, 12:50 PM   #15 (permalink)
Or you can have a local do it for you with an open flame in the shop and burn down your house (not me another local guy had this happen). Really sucked for the home owner.
