Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > US Regional Forums > Northwest
Old 09-18-2004, 11:48 PM   #1 (permalink)
RedNeonSport's Avatar
Member Number: 13835
Default New header installed and dynoed my car today...
Header was built by Eric Urness (R/T Ernie), and ceramic coated satin black by Finishline Coatings. It's got 1.75" primaries, and a merged tri-y (or 4-2-1, whatever you call it) collector. The header has a 3" outlet and an extra bung for wideband O2 readings.
Engine mods are:
3.0CAI, TTI UDP, Mopar ECU, ATX TB, long tube race header with merged 4-2-1 collector, 3" cat, dynomax 2.5" resonator, 2.5" hooker max flow.
The engine has 113k miles on it. I've got a/c and p/s belt on. 15k miles on spark plugs checked before dyno runs... seemed a bit too white... running lean I thought?
I noticed something weird around 6.5k rpm on the dyno graph... like it was misfiring or something... but it didn't sound like that, and I got no codes. It did this on each run about the same rpm.
RedNeonSport is offline   Reply With Quote
Old 09-19-2004, 12:06 AM   #2 (permalink)
Azi
Azi's Avatar
Member Number: 11510
jeez, what do you redline @? i guess i just never knew neons redlined above 7k. maybe that's just the ecu upgrade.
not sure about the 6.5k rpms. otherwise, good job with the new install.
SRT gone. Exchanged for a G8 GT Hybrid*.
*2000 V8 WS6 T/A (gone) + 2002 Grand Prix GTP Sedan (gone) = 2009.5 V8 Sedan G8 GT
Azi is offline   Reply With Quote
Old 09-19-2004, 12:15 AM   #3 (permalink)
Redline with the DOHC Mopar ECU is 7.5k rpm... heck, that's nothing.
When I go with stand-alone EMS, it'll probably be around 8500rpm!
Old 09-19-2004, 06:56 PM   #4 (permalink)
Ceyvme's Avatar
Member Number: 14587
Better upgrade cams before that, or you'll just be making no power and alot of engine noise and wear ~
Ceyvme is offline   Reply With Quote
Old 09-19-2004, 07:06 PM   #5 (permalink)
jaymzx's Avatar
Member Number: 278
Trader Rating: (12)
Indeed...get some gnarly cams on there and bring it to life
Good jorb.
James NWSRT-4
READ AND LEARN:
Old 09-19-2004, 07:29 PM   #6 (permalink)
04srt4silver's Avatar
Member Number: 2482
not for nothing but why spend all that money for 130 hp?
04srt4silver is offline   Reply With Quote
Old 09-19-2004, 08:37 PM   #7 (permalink)
jaymzx's Avatar
Member Number: 278
Trader Rating: (12)
Actually, that's a gain of about 40whp from stock.
Not everyone is into turbo cars...
Old 09-19-2004, 10:29 PM   #8 (permalink)
As for cams, I'll be getting Crane #18 cams. 223' duration at 1mm lift.
04srt4silver: Why spend $1k on engine mods? Cause it's fun!
Stock DOHC Neons are around 100-120whp. Depending on miles and how tuned their cams came from the factory.
Old 09-19-2004, 11:22 PM   #9 (permalink)
RedEuroNeon's Avatar
Member Number: 9291
Yeah... get camshaft, adjustable cam gear, lot's of head work, Pt valve train, oversize valves, valve springs, and extrude the intake manifold. Yeah my car was only making 131 whp at 135 ft/lbs... until my car started making a knocking noise. I did not make as much hp because I did not have camshaft, adj cam gear, oversize valves, and intake work. Oh well... getting any SRT-4 anyway... enough playing with N/A... too hard to make enough hp.
Nathan
POS SRT-4 Just waiting for another part to fall off!
RedEuroNeon is offline   Reply With Quote
