Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums 1 > Northwest
Old 05-09-2008, 06:07 PM   #1 (permalink)
tyeayo's Avatar
Member Number: 37734
Default Needswings V.5 question
Ok, so I ordered this the other day, and am still not clear on what if anything needs to be done to keep from throwing "no cat" codes....
I have an 04 stage 1....do i need to do anything, can i still screw in my o2 sensor?? Or do i leave in out and ziptie it outta the way?? this is the catless dp too btw.....
thanks guys
tyeayo is offline   Reply With Quote
Old 05-09-2008, 10:06 PM   #2 (permalink)
DrmCtchr's Avatar
Member Number: 38971
if there is a bung for it, plug it in =] stage 1 doesnt use it so much. remember its heated so if you zip tie it out of the way make sure its far far away from fuel lines and brake lines and anything that might melt. Either way works fine =]
David
DrmCtchr is offline   Reply With Quote
Old 05-10-2008, 07:34 PM   #3 (permalink)
radicalmark29's Avatar
Member Number: 55274
Trader Rating: (10)
There's a hole. STG 1 will keep you from throwing a code. Quit being a weiner.
radicalmark29 is online now   Reply With Quote
Old 05-10-2008, 07:39 PM   #4 (permalink)
tyeayo's Avatar
got it done....I had 3 bungs in mine.....one was plugged and two were open.....went to schucks and picked up an oil drain plug and popped that in the 3rd bung....no problemos!!
installing the PTP o2 and the pipe was a biznatch though....but well worth it.....the shit sounds mean....definetly noticing a quicker build of the boost.....and it pulls harder too.....very much worth the moolah
Page generated in 0.12706 seconds with 11 queries
