11-15-2007, 05:14 PM
#1 (permalink )
Member Number: 49320
Need a tool in vancouver.
Any one in vancouver have a brake compressor they will let me borrow for a few mins? Give me a call 360-608-3133
11-15-2007, 05:16 PM
#2 (permalink )
Member Number: 40796
Use a c-clamp to compress the piston
11-15-2007, 05:32 PM
#3 (permalink )
Member Number: 33036
crack open the bleed screw a 1/4 turn and try to push the pistin in, then tighten the screw back up
11-15-2007, 05:35 PM
#4 (permalink )
^^ Also works
11-15-2007, 05:51 PM
#5 (permalink )
Member Number: 14173
C-clamp ftw.
Stg. 2 w/o, AEMuego/map clamp & CAI, AGP WGA, ED Wuss IC, PTP 55mm TB & O2 housing, MaxxFab 3"dp w/resonator & Mopar Exhaust, ported intake & exhaust mani's, S1 springs, budget sways, DC strut bars, Prothane race inserts, Eagle F1 GS-D3's
Quote: Originally Posted by my grundle is hairy
i'll keep posting til my grundle goes bald
11-15-2007, 06:02 PM
#6 (permalink )
Member Number: 58097
c-clamp....cheap/fast. If you wont want to marr your housing, just put a piece of wood between the housing and the end of the c-clamp on the exterior portion not on the piston side
11-15-2007, 06:12 PM
#7 (permalink )
Member Number: 15950
You can have our north end tool...........as long as you don't give him back. He is worthless but he will tell ya he knows it all and has done it for longer than god himself.
11-15-2007, 07:10 PM
#8 (permalink )
Member Number: 25514
Put the caliper in the rotor and then pry the pads back with a screw driver. Works most the time if you are not replacing rotors with the pads. If you are doing pads and rotors you will need a c-clamp to get the piston in all the way.
11-15-2007, 08:02 PM
#9 (permalink )
I broke down and bought the tool for 42$
11-15-2007, 08:19 PM
#10 (permalink )
Member Number: 43129
Well at least you will have it for next time! The right tool always makes the job easier
11-15-2007, 09:05 PM
#11 (permalink )
I had to buy a jack too.
11-15-2007, 09:48 PM
#12 (permalink )
damn man, does it look like you used the tool? try to return it and go over to harbor freight and get a C-clamp for $2.89
As for the jack, you will use it alot
11-16-2007, 01:07 AM
#13 (permalink )
^ i second this motion
11-16-2007, 02:10 AM
#14 (permalink )
Member Number: 35663
Sounds like an ad in a men seeking men publication.
SWEETS TO DO LIST:
Free Carlos X
Take over the world
Bungee Jump
SKinny dip X
Kiss a girl
Touch Coy XXX
11-16-2007, 02:42 AM
#15 (permalink )
Jesus coy, why dont you just cut my balls off while your at it......
Linear Mode
» Site Navigation
> Other Vehicles
» Network Links
