Hey guys, I've been searching this forums for 2 days now. I still have no answer for my need. As the title says I need more power, I'm starting to get that bored feeling with my car.
My mods so far are:
Stage2
3" Catless DP
3" Cat Back
PTP WGA
ED Beast FMIC
AEM Cold Air Intake
Grounding Kit
MM Inserts
Mopar STS w/Bushings
Mopar BOV Plate
Dual Stage Boost Controller
I also have the PTP mapclamp on order
Any help would be great, I can't think of anything. I have about $250-$300 to spend right now.
My mods so far are:
Stage2
3" Catless DP
3" Cat Back
PTP WGA
ED Beast FMIC
AEM Cold Air Intake
Grounding Kit
MM Inserts
Mopar BOV Plate
Thanks
Alcohol injection.
ATTN : Everything said on the forums is 80% truth at BEST
I am not your role model, I am not here for you to look up to, I am not here to mentor you.
I am here to moderate you, and occasional Pimp Slap you A$$ when you get out of line.
I agree with Zane. Devils own water/meth injection. That will be under $300 easy and will help you out a lot. I never drive my car without mine turned on anymore. Makes the intake cooler, gives good knock resistance and you can add fuel by using meth so you can run a more aggressive tune. Will work just as well with stock turbo as it will big turbo so you are not wasting money for parts you will not use later.
