Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 1 > Northwest
Old 12-28-2007, 04:51 PM   #1 (permalink)
Member Number: 55070
Default My route?
Im planning on ordering
ptp wga
FPR mod
MAP/TIP clamp
I dont see my self going big turbo so thought id stay with basic bolt ons to get around 270 + hp.
Already got full borla 3 inch exaust
Stg 1 pcm and injectors
CAI
Just wondering what your guys input is on this. I thought the things im planning on ordering would work good to be boosting around 18 lbs.
Will i need a boost controller later to run with the map clamp and wga. Or will the wga be able to set my boost? Thanks dudes
Names Kyle, you can call me tommy
Myspace- myspace.com/neon_ftw22
Add me if you got it
Tommy the SRT is offline   Reply With Quote
Old 12-28-2007, 04:52 PM   #2 (permalink)
Plan B's Avatar
Member Number: 43129
You can control your boost with just the WGA, but having an MBC will help you spool faster....
FYI - You will need more than that for 270+ whp....
Plan B is offline   Reply With Quote
Old 12-28-2007, 04:59 PM   #3 (permalink)
AEMpimp's Avatar
Member Number: 46379
Tommy, for 270 plus you will need more then that i suggest you go stage 2 and do it right if you dont plan on changing out the turbo. for about 1000 i think is the price if anything find a used Stage 2 PCM and peice it together, but for the FPR and map clamp you need a wideband so that is another 275 bucks on top of what you bought just to get it to work right. So i would think about it long and hard what you really want because its always best to do it right the first time man. also if you dont have a 3 inch downpipe i would look into that stock downpipe chokes these cars up really bad i hope it halped just giving my 2 cents
AEMpimp is offline   Reply With Quote
Old 12-28-2007, 05:07 PM   #4 (permalink)
Ok good info guys. Stage 2 is prolly the way to go. Ill look into the down pipe. I wanna make sure to do it right the first time your right
Old 12-29-2007, 12:09 AM   #5 (permalink)
BobRoss46n2's Avatar
Member Number: 23740
Also check the performance section....
There is a "300hp with stock turbo" sticky.
...Hmmm.....
Here it is.
How 2: 300whp Stock turbo...again
BobRoss46n2 is offline   Reply With Quote
Old 12-29-2007, 01:10 AM   #6 (permalink)
Skittle's Avatar
Member Number: 51131
Dont waste your money on stage 2 or even a stage 1 pcm for that matter. Stage 1 injectors are a must if your car didnt come with them.
Do,
Peak out stock turbo and have money left with:
CAI
3''TBE with o2 housing
WGA
Map Clamp
MBC
FPR
A tune after this of course
I made 277whp and 293wtq then 280whp and 303wtq with no map clamp or mbc or FPR. Stage 0 also, things are possible.
Skittle is offline   Reply With Quote
Old 12-29-2007, 03:31 AM   #7 (permalink)
Do,
CAI
WGA
Map Clamp
MBC
FPR
Isn't that what i basically said. Get WGA, Map clamp, and FPR. Cept you added the MBC
And yeah i already go the stage 1 injectors.
Old 12-29-2007, 08:50 AM   #8 (permalink)
COY
COY's Avatar
Member Number: 35663
Trader Rating: (27)
It never stops.
We have all said I would be happy with "insert number here" and then kept right on spending.
SWEETS TO DO LIST:
Free Carlos X
Take over the world
Bungee Jump
SKinny dip X
Kiss a girl
Touch Coy XXX
COY is offline   Reply With Quote
Old 12-29-2007, 11:03 AM   #9 (permalink)
Skittle's Avatar
Yes it is, you mentioned stage 2 is the way to go also, its not.
Old 12-29-2007, 02:04 PM   #10 (permalink)
im already thinking to my self. Why would i go stage 2 if i can just save some more and get stage 3. Ill just keep on storing that money and post when i got it
Oh and heres some pics of the neon. My friend took em with his rebel xti.
Yes i know it needs to be dropped a bit
Old 12-29-2007, 02:40 PM   #11 (permalink)
Wow....Uuuhhh
Cool
Old 12-29-2007, 05:09 PM   #12 (permalink)
oops. LOL heres the link
Flickr: Photos from DannyWagner
Old 01-03-2008, 08:13 PM   #13 (permalink)
So im thinking about just buying all the stage 2 parts separate.
Ill need the injectors, wga, pcm and 3.0 tip sensor.
What exactly does the 3.0 tip sensor do?\
Oh and i was thinking about buying the injectors first because someone had them for sale on the forum for 200
Old 01-05-2008, 02:04 PM   #14 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (554)
Smile
ptp wga
FPR mod
MAP/TIP clamp
CAI
I would get the pump rewire as well. Do you have the CAT CONVETER on the car still? If so getting rid of that for running on the dyno would be good for another 15 to 20 WHP.
You will be very close to 270 WHP. Here is chart of a another car with the same mods. This car only had 19 psi on it and we had very little tune on the car due to it being out of fuel up top. With a rewire on the pump we could have added that extra 3 psi and got some tuning done with the map clamp. This was also a stock PCM car as well.
File Type: jpg DP with map clamp and low boost 19 psi.JPG (69.0 KB, 7 views)
Old 01-05-2008, 02:07 PM   #15 (permalink)
...Hmmm.....
Here it is.
We have done it with a lot less on the car. Hell we hit 301 with no tune on an SST. If you want 300 WHP there are much easier ways to make it happen, just an opinion not an attack.
