Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 1 > Northwest
Old 06-21-2004, 02:38 AM   #1 (permalink)
Member Number: 10614
Default Motor Problems Help!
My motor is idling wierd it is normally at 800rpm but it keeps going down to... 5-600rpm and up to 2300rpm when its sitting out of gear or with clutch in....Maybe a vacum line off??? any ideas????cell #253-835-3385
Spencer
thanks.
dangerous_mind98023 is offline   Reply With Quote
Old 06-21-2004, 04:47 AM   #2 (permalink)
Member Number: 4698
I had that problem before, I would idle between 600-1400. One time it just went straight to 3000 until I pushed the clutch. It might be the wiring to your TPS. That's what mine was.
-Demo-
demo_srt4 is offline   Reply With Quote
Old 06-21-2004, 12:27 PM   #3 (permalink)
SRToc Member
jaymzx's Avatar
Member Number: 278
Trader Rating: (12)
Yea. Check the wiring and connectors around your throttle body, and also check for vacuum leaks.
James
READ AND LEARN:
Old 06-21-2004, 05:21 PM   #4 (permalink)
Member Number: 7782
yea.. same prob here. I have the mopar BOV, it would blow off while I was accelerating.. ended up being the TPS ground wire.
Hitman_Srt4 is offline   Reply With Quote
Page generated in 0.20661 seconds with 13 queries
