Dyno tuning will vary from real street tuning. I would be sure if you dyno in the day that you go for a conservative tune...such as 11.9 to 12.1 AFR. Considering while running at night the AFR will go up. Purchasing a wideband would be a good idea also. I just bought the PLX M300 wideband and absolutely love it. Then you spend the money on a Greddy E01 boost controller and you can use the analog outs on the wideband to directly feed into the E01 and datalog. Also if you buy a tach adapter you will be able to do AFR per RPM logging which is awesome....and did I mention also that it's one of the most precise EBC on the market.....and its under 500bux.
[X]Your Mom
[X]Your Sister
[ ]Your Girlfriend
Working on the 3rd right now.......
or buy the zetronics kit and for $75 more you can datalog egt's, afr's, boost, rpm, and lambada (sp) all in one unit and it comes with a niffty pannel to view all the info on.
Rofl....Bang for the buck the Greddy E01 is the ish. If I was in your position I would buy a Zeitronix kit and plug that directly ino the E01. Also purchase a tach adapter and hook that up also. Once at that point you will have a portable logging station that is very user friendly. Dynoing is the way to get a base tune but be sure to go conservative as you will see higher AFR's at night. The E01 will also save each logged run onto a SD card which you can also upload to your computer and study it. I am sure John will be able to get you setup with a good tune on the dyno.
You can get it tuned at Intec and that won't be a problem. But I highly suggest a conservative tune since you will see a variance between dyno load and a street load, which all in all will vary your AFR's. I would have someone go with you that knows how to dial in a mapclamp and suggest to them that you would like it dialed into a 12.0AFR or slightly under. Your AFR will be slightly higher when driving at night. Happy tuning.
