Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums 1 > Northwest
Old 07-18-2008, 05:32 PM   #1 (permalink)
Member Number: 55070
Default How to on motor mount install?
Ok so i got my agp motor mounts waiting to be installed at home.
Just a quick question, seems fairly simple to install. Do i need to support the engine at all, while switching them out, I heard i need to. If so where is this point at? Thanks dudes
Names Kyle, you can call me tommy
Myspace- myspace.com/neon_ftw22
Add me if you got it
Tommy the SRT is offline   Reply With Quote
Old 07-18-2008, 05:35 PM   #2 (permalink)
blackSRT-4me's Avatar
Member Number: 22724
get a block of wood put on jack and jack on tranny I know it sounds bad but it works its only needed when doing the lower and tranny mount though.
blackSRT-4me is online now   Reply With Quote
Old 07-18-2008, 05:57 PM   #3 (permalink)
Im only doing the upper and lower passenger side mounts. Do i gotta jack the engine for one of those
Old 07-18-2008, 06:00 PM   #4 (permalink)
Plan B's Avatar
Member Number: 43129
No. What you are replacing are actually tension strut like pieces, not the actual motor mount. The mount itself will not be disconnected. You can replace both on the passenger side without a jack. I recommend you get the tranny mount as well, I've heard some weird things happening with solid on one side and stock/soft on the other.
Plan B is offline   Reply With Quote
Old 07-18-2008, 06:01 PM   #5 (permalink)
yup for the lower mount not much to jack up though it should take 30 mins tops to do both.
Old 07-18-2008, 06:02 PM   #6 (permalink)
word homes I had to jack mine up a bit for the bolt to line up.
Old 07-20-2008, 01:47 PM   #7 (permalink)
COY
COY's Avatar
Member Number: 35663
Trader Rating: (27)
Torque arms installation manual 1
Torque arms installation manual 2
Located in Kitsap County, I am the Northwest's premier sport, luxury, and import tuning facility.
Apparently that is all you have to do to make that claim.
COY is online now   Reply With Quote
Old 07-20-2008, 02:19 PM   #8 (permalink)
White Heat's Avatar
Member Number: 512
Trader Rating: (10)
I'd support the engine unless you want to possibly have to recalibrate the positioning. The manual calls for recalibrating the engine position so I'd support the engine so it don't move and you don't have to do that.
'05 Stone White SRT 4
Mods - Yes
Web Page
http://qt.ptenthusiasts.net/
White Heat is online now   Reply With Quote
Old 07-24-2008, 03:10 PM   #9 (permalink)
Guys quick questions before the install!
Should i use locktite on the bolts. Or no. I got it, was just wondering if you guys did/ Cause im sure its a bitch to get off if i use it
Old 07-24-2008, 03:13 PM   #10 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (548)
Use loctite to keep them from backing out. Use the blue not red.
Old 07-24-2008, 03:15 PM   #11 (permalink)
Fuck is there a difference, I just picked up some, lol i got the red. Should i go back and exchange it
Old 07-24-2008, 03:46 PM   #12 (permalink)
kup@l's Avatar
Member Number: 53972
I'm planning to use dogbones MM's. I searched and read the sticky but no pics. ^^^ Read the above link posts. Very helpful and I thank you. I just have one question though, if I install the dogbones, will the whole thing get out of alignment? Like what I mean is, when you bolt it up, will it mount up straight like the stock ones? Thanks guys
-Davey
kup@l is offline   Reply With Quote
Old 07-24-2008, 05:05 PM   #13 (permalink)
Guys i cant get the freaking lower mount off. I used a jack and have been moving it up around it and it wont align to come unscrewed. Ive tried really hard lol. Any tipss
Old 07-24-2008, 05:54 PM   #14 (permalink)
Also i couldn't get it off. Isf it bad to run with the agp dog bone mount on top and the stock mount on bottom. I wouldn't think it would be
Old 07-24-2008, 06:12 PM   #15 (permalink)
Member Number: 11814
Trader Rating: (91)
Hard to understand that you are having an issue getting it off and reinstalled (no hate just have done this and IMO its easy). The R/S of the engine has a mount plate that the motor pivots on, by jacking up near the oil pan tranny in the front closest to the rad support you should be able to pivot the engine/tranny so that you can easily remove and install the torque struts = get things lined up so that coming off things are not binding and going on things get lined up.
In the service manual theres a procedure for getting the engine/tranny properly positioned, its an easy task and it should be done any time any of the tension struts are removed or the clutch is serviced.
Heres a link to the service manual, it may make sense at this point to look for help in here OR post up images to better help you figure out what you are getting stuck with.
**** SRT-4 / Neon Service Manuals ****
Page generated in 0.29642 seconds with 11 queries
