Driver's power window problem - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > US Regional Forums > Northwest
Old 12-27-2010, 08:23 PM   #1 (permalink)
R(k)'s Avatar
Member Number: 80585
Default Driver's power window problem
My driver's side power window recently became very slow and eventually stopped working altogether. My passenger window is as fast as it's ever been.
I replaced the window motor but no dice- still won't budge. I felt around in there for anything that could be binding but the track feels clear. The motor turns freely when not attached to the other half in the door.
I don't know how to diagnose that other part, I've never encountered a cable unit like that.
Ideas?
R(k) is offline   Reply With Quote
Old 12-27-2010, 08:37 PM   #2 (permalink)
DreSRT's Avatar
Member Number: 54384
i had the same problem and all i did was take the switch apart and sanded the little metal ends and it has been working ever since.
Dear honda Owner, your vtec is not a turbo.
DreSRT is offline   Reply With Quote
Old 12-27-2010, 09:07 PM   #3 (permalink)
Member Number: 19673
yup, corrosion on the switch can really kill it
Project: Heavyweapon
"Wrong wheel drive for all the right reasons."
PTE6266: 10.65 best et | 139mph best trap | 1.62 best 60'
Let the quest for single digits begin!
Find more pictures and info:
Build Thread | Facebook | Instagram
Checksum is offline   Reply With Quote
Old 12-27-2010, 09:30 PM   #4 (permalink)
R(k)'s Avatar
Cool, thanks. I'll check the switch contacts tomorrow.
Old 12-27-2010, 09:53 PM   #5 (permalink)
jaymzx's Avatar
Member Number: 278
Is the regulator binding or anything?
James
READ AND LEARN:
Old 12-27-2010, 10:00 PM   #6 (permalink)
R(k)'s Avatar
Not that I can tell, but I've never seen a regulator like this so I'm a little unsure. I've run my hand up and down the guide rail and the center lift and I don't feel any obstructions or anything really that would be in the way.
I have to think if it was something binding that it would have simply seized instead of slowly becoming inoperable, but I could be wrong.
Old 01-03-2011, 01:25 AM   #7 (permalink)
DreSRT's Avatar
did you ever get this fixed?
Old 01-03-2011, 10:17 PM   #8 (permalink)
R(k)'s Avatar
Nope, I went out and pulled the switch panel and cleaned all the switch contacts even though they were pretty bright. Still the same deal.
If I get time this week I am going to pull the door panel back off and see if I can figure out where it might be binding or caught.
I was thinking maybe there was a relay as well, but it doesn't seem normal for a relay to fail in this fashion (slow, slower, dead).
Old 01-04-2011, 07:01 PM   #9 (permalink)
"Made" Member
inzanesrt4's Avatar
Member Number: 1426
Both Windows should be on the same power window relay.
inzanesrt4 is offline   Reply With Quote
Old 01-04-2011, 10:27 PM   #10 (permalink)
R(k)'s Avatar
Passenger side performs great. Guess I can rule out the relay if they use the same one.
Old 01-09-2011, 04:57 AM   #11 (permalink)
Space's Avatar
Member Number: 32199
Did you grease the shit out of it? Mine's the same. In fact I quit using my drivers side since the cold weather started months ago. The warmer it is, the better it seems to work. I thought maybe the motor was dying since I use it all the time. Perhaps the grease is wore out/broke down, and with the colder weather, it might be thickening up. I don't know, hopefully you can figure yours out so I'll know what to do to mine. Mine will go down, but hell if I'll trust it to go back up, so I leave it up.
Space is offline   Reply With Quote
Old 01-09-2011, 11:54 AM   #12 (permalink)
jaymzx's Avatar
Member Number: 278
Beats a stuck sunroof
James
READ AND LEARN:
Old 01-13-2011, 12:28 PM   #13 (permalink)
DreSRT's Avatar
damn sux to be whoever owned that cat.
Old 01-13-2011, 09:48 PM   #14 (permalink)
Hi N Mity's Avatar
Member Number: 33036
our old accord had the same problem. we had to pull up on the window to get it started when we wanted to close it. We replaced the whole window switch and it fixed the problem. the problem is under the switch levers/toggles, not where the harness connects to the assembly. head to a junk yard and find a switch assembly. Normally they pull those kind of parts before putting them in the yard, but its wortha shot
Old 01-13-2011, 09:52 PM   #15 (permalink)
Hi N Mity's Avatar
00 05 DODGE NEON MASTER DOOR WINDOW SWITCH - eBay (item 170588873766 end time Jan-16-11 11:29:53 PST)
