Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 1 > Northwest
Old 08-26-2009, 10:47 PM   #1 (permalink)
BOOST-LEAK's Avatar
Member Number: 73174
Default Clutches
Whats a good but cheap clutch and not STOCK.
BOOST-LEAK is offline   Reply With Quote
Old 08-26-2009, 11:20 PM   #2 (permalink)
MyGreenMachine's Avatar
Member Number: 24943
act 6 puck unsprung lol
actually the street disc is pretty good
Edited by Inzanesrt4
MyGreenMachine is offline   Reply With Quote
Old 08-26-2009, 11:26 PM   #3 (permalink)
conroy9940's Avatar
Member Number: 46401
Trader Rating: (114)
southbend stage 3.
Pittsburgh Penguins 14-8-0 28 points
Old 08-26-2009, 11:42 PM   #4 (permalink)
srt4-perry's Avatar
Member Number: 14326
spec stage 2 or stage 2+
262WHP/320WHP
stock unmolested turbo
12.29 @ 111.99
srt4-perry is offline   Reply With Quote
Old 08-26-2009, 11:54 PM   #5 (permalink)
SRTforums Junior Admin
inzanesrt4's Avatar
Member Number: 1426
Quote: Originally Posted by conroy9940 View Post
southbend stage 3.
Ditto.
Drives like stock. Handles I belive up to 350HP reliably. I bought mine from PTP. Not sure if he still sells southbend but I believe he still offers a discount on install if you buy the clutch from him. Also no 4+ hour wait like most shops he gets them done in like two hours. probably half that time but I was trying to help.
I believe Real Tune sells and recommends the Southbend as well.
Quote: Originally Posted by srt4moster View Post
he is doing good, i make sure to play with him everytime im there.
inzanesrt4 is online now   Reply With Quote
Old 08-27-2009, 12:31 AM   #6 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (567)
Good, cheap and not stock.... I don't think that is possible. We can do $899 for a clutch but your going to need TOB fork arm, slave cyl and instalation. We offer installed packages for $1199 and this is getting rid of the modular design and going with a true 3 piece set up with a 4140 moly flywheel. This clutch will support up to 550 WTQ easy with the potential holding power being closer to 700 WTQ. These are also set up to run higher RPM's with out the worry of shifter lock out. Let me know if you want to go this way or stick with the modular set up.
Thanks.
The street disk is not bad but will not take any kind of track abuse. 6 puck again a good clutch but seems to slip around 500 WTQ on slicks.
southbend stage 3.
Best option out there if you ask me. $575 shipped to your door.
I think he said good clutch, Spec has a horrible reputation with the SRT4's.
Quote: Originally Posted by inzanesrt4 View Post
Ditto.
Drives like stock. Handles I belive up to 450 + HP reliably. I bought mine from PTP. Not sure if he still sells southbend but I believe he still offers a discount on install if you buy the clutch from him. Also no 4+ hour wait like most shops he gets them done in like two hours. probably half that time but I was trying to help.
Fixed it for you, they install can be tricky with some cars but that is about the turn around time if all goes smooth. We are going to be taking a look at doing a GB here very soon.
Quote: Originally Posted by lyncoo View Post
do not get act
Agreed, they are not bad for daily driver, but when you start to ask to much of them they will give you some issues with holding.
Home of the DSP Tuned 657 WHP SRT4 Neon, 593 WHP SRT4 Caliber and the fastest stock turbo DSP tuned SRT4
DSP or Trinity
Old 08-27-2009, 12:57 AM   #7 (permalink)
Member Number: 36825
Check out modern automotive performance got a act hdss system 630 shipped!
SRT Jeff is offline   Reply With Quote
Old 08-27-2009, 11:44 AM   #8 (permalink)
Plan B's Avatar
Member Number: 43129
I ordered a Southbend stage 3 from Realtune. Comes with a TOB. Install was easy (as easy as a clutch install can be ) and it has handled everything I have thrown at it. Drives like stock as Zane stated and hasn't slipped once. Last dyno I did was approx. 340 whp and 409 tq @ 18psi. I have since been running at 26 psi, race gas, and HOM and the clutch has handled all the tq I could throw at it. Not sure how much tq that is but I feel confident that it is over 450 and probably closer to 500 (just a guess). For under $600 shipped you really can't go wrong.
I would also like to add though that a lot of locals have had issues with this clutch, mostly being vibration. Pretty sure SBC has corrected the problem, but you should be aware anyways.
Plan B is offline   Reply With Quote
Old 08-28-2009, 03:23 PM   #9 (permalink)
COY
COY's Avatar
Member Number: 35663
Trader Rating: (41)
I have a southbend stage 3 clutch used for 2000 miles. Never raced with and I drive like a girl. It had the vibrations that went along with the first gen bolts. I just got it back from Southbend where they replaced bolts and checked balance and called it good to go.
Your or anyones for $300 shipped.
Quote: Originally Posted by Flame View Post
Coy is and always will be at least 99% better then me on my best day
PTP = ignored
COY is offline   Reply With Quote
Old 08-28-2009, 03:27 PM   #10 (permalink)
Member Number: 48589
Trader Rating: (50)
We have the ACT in stock ready to rock... One of the best clutches on the market if you ask me.
05 SRT-4
S-256
Stage 0
E-85
450hp all day every day.
Modern Automotive Performance: Your source for SRT-4 performance parts!
763-545-3800
burd@maperformance.com
AIM: burdatmap (Best way to contact me!)
maperformance is offline   Reply With Quote
Old 08-30-2009, 08:12 PM   #11 (permalink)
Plan B's Avatar
That's a damn good deal!
I can also vouge for Coy driving like a Grandma....
Old 08-30-2009, 08:48 PM   #12 (permalink)
need4speed2345's Avatar
Member Number: 59269
stock
close REAL close to 400whp on it too
03 SRT4-|Delta 44 Turbo|3 Inch CTI Turbo Back Exhaust|NOS Sniper Kit 50 shot|Coolingmist trunkmount Meth Kit|MBC 24PSI|MPx Front mount|750CC DW|AGP External Wastegate|378/402
93 Civic Hatch-STOCK D16 high boost build in progress
need4speed2345 is offline   Reply With Quote
Old 08-30-2009, 09:36 PM   #13 (permalink)
COY
COY's Avatar
Trader Rating: (41)
thats creepy.
Old 08-31-2009, 01:04 AM   #14 (permalink)
kingj07's Avatar
Member Number: 2988
thats creepy.
x 2..
By deafness one gains in one respect more than one loses; one misses more nonsense than sense.
horace walpole
kingj07 is offline   Reply With Quote
Old 08-31-2009, 05:41 PM   #15 (permalink)
Plan B's Avatar
Would it be better if I said I can Vogue for Coy?
Page generated in 0.19996 seconds with 13 queries
