Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 1 > Northwest
Old 09-07-2009, 07:21 PM   #1 (permalink)
srt1002's Avatar
Member Number: 31942
Default Check these numbers out
Realtuned ftmfw
AGP D60 HTA numbers! Bad arse!
Stock ACR
srt1002 is offline   Reply With Quote
Old 09-07-2009, 07:38 PM   #2 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (567)
Great numbers, but looks pretty similar to the BW362 (see attached dyno sheet). I should have started the dyno pull a little earlier and this is only running 26 psi not 30 psi.
What is the price of this turbo?
Home of the DSP Tuned 657 WHP SRT4 Neon, 593 WHP SRT4 Caliber and the fastest stock turbo DSP tuned SRT4
DSP or Trinity
Old 09-07-2009, 08:26 PM   #3 (permalink)
srt1002's Avatar
Not sure about pricing or which one they exactly have, but I do know it's in the $1100 range
Old 09-07-2009, 09:16 PM   #4 (permalink)
Same price as the BW 362 which is a great turbo, seems that the D60 is a good turbo as well. I hope that they can get more out of it over at RT.
Old 09-07-2009, 09:23 PM   #5 (permalink)
srt1002's Avatar
So what is the difference between an AGP BW S362: And yes I do know that this is just an S360, but had nothing to compare it was this or a 366....
AGP Turbochargers, Inc. :: Borg Warner Turbos :: S300 Series :: Borg Warner S300 S360 Turbocharger
And this Bullseye/ Borg Warner
Bullseye Borg Warner S362 Turbo .55A/R or .70A/R Extended Tip - Turbochargers.com
Old 09-07-2009, 09:29 PM   #6 (permalink)
Member Number: 24595
Id say there not that close. Look at torque comparision between the 362 and the d60. Try again.
Correction. It makes "similar" numbers, but the d60 makes em 500 rpms sooner.
staywide8 is offline   Reply With Quote
Old 09-07-2009, 09:32 PM   #7 (permalink)
Member Number: 68182
i heared one of are local guy will be runing this turbo
Raman04srt is offline   Reply With Quote
Old 09-07-2009, 11:39 PM   #8 (permalink)
srt1002's Avatar
Shhhhhhhh
Old 09-08-2009, 12:46 AM   #9 (permalink)
SRTforums Junior Admin
inzanesrt4's Avatar
Member Number: 1426
If you are comparing the PTP dyno to the Real Tune Dyno its comparing the taste of pears and carrots.
One dyno sheet is corrected one is uncorrected, one is running @26psi one at 30psi dynos set up differently etc...
Quote: Originally Posted by srt4moster View Post
he is doing good, i make sure to play with him everytime im there.
inzanesrt4 is offline   Reply With Quote
Old 09-08-2009, 01:01 AM   #10 (permalink)
inzanesrt4's Avatar
Member Number: 1426
I heard this thread would be littered with drama soon.
Old 09-08-2009, 02:02 AM   #11 (permalink)
kingj07's Avatar
Member Number: 2988
they were doing quite well, zane.
By deafness one gains in one respect more than one loses; one misses more nonsense than sense.
horace walpole
kingj07 is offline   Reply With Quote
Old 09-08-2009, 06:36 AM   #12 (permalink)
HUH? I'm comparing the 500 rpms earlier power. Whats correction have to do with that? Or really even dyno. Maybe a touch diff, but not a whole lot.
Old 09-08-2009, 10:54 AM   #13 (permalink)
I think that going WOT sooner would have netted much closer results. I do have dyno results showing what 28 psi made, if you want to see them I will post them up. Have not ran 30 psi yet on the dyno, when I do I will be sure to post up the results.
Thanks.
Old 09-08-2009, 10:57 AM   #14 (permalink)
I don't know what the difference's are but the D60 should be very similar to a S360 with a smaller AR housing on the S360. S360 with the 55 A/R housing from us is $799 and add $200 for the RS compressor wheel. I would have to say that this turbo would make very similar numbers with a good tune on it.
Old 09-08-2009, 11:30 AM   #15 (permalink)
SRT of the Month
ERABBIT23's Avatar
Member Number: 39786
Trader Rating: (56)
we are not honestly comparing the D60 which flows around 60lb min to the BW S362 which flows in the 70lb a minute range are we?
Worlds Fastest 5 Speed NSRT-4 ET and MPH
Only SRT-4 Trapping 150+ Without Nitrous
Built and Tuned by Realtune Powered by AGP Turbo and Cylinder Head by Darrel Cox Racing
Check Out ERABBIT23 on Youtube 4 Videos!
ERABBIT23 is offline   Reply With Quote
Page generated in 0.20470 seconds with 14 queries
