Turbo Timer Help
Ok So I just installed a apexi turbo timer in my car following the how to and when I shut my car off while it is in gear it just goes off which is a safety feature I guess obviously since the car cannot be left running in gear without the clutch depressed however my second question is this if I start the car with it in neutral the turbo timer begins to count down from the set time and when it reaches zero it just resets and stops counting other than that everything seems to work fine is this normal for the apexi turbo timer or did I do something wrong. Thanks and any help would be appreciated.
