Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Technical Discussion > Technical Tuning & EFI/EMS Electronics > Electronic Boost Controllers & Turbo Timers
Old 01-12-2009, 10:56 PM   #1 (permalink)
Member Number: 62699
Question Problems.........
So far the car is leaning out really bad.
I have checked all of the lines, but for some reason on the bottom of my boost control valve (apexi). There is a bleeder valve and im not sure what its for. I have had a couple of people tell me to plug it, but i cant help to think that its probably on there for a reason.
Does any one know anything about these.
Dcrtdr1 is offline   Reply With Quote
Old 01-12-2009, 10:58 PM   #2 (permalink)
BigBird03's Avatar
Member Number: 60153
Trader Rating: (42)
I dont think your boost controller would lean your car out.
BigBird03 is offline   Reply With Quote
Old 01-13-2009, 01:09 PM   #3 (permalink)
It is possible because if it hooks into the fuel pressure regulator, like most do then it could possibly mess up and then make the fuel pressure regulator think it is running less boost which would make the regulator put out less fuel, then lean the car out.
Old 01-13-2009, 10:08 PM   #4 (permalink)
BigBird03's Avatar
Trader Rating: (42)
Your boost controller hooks up to your regulator????? lol
Old 01-13-2009, 10:30 PM   #5 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
ok, just make sure your turbo gets a boost only source and make sure its before the bleed and not after
...............- FPR
turbo- tee = -boost controller -waste gate
Old 01-16-2009, 12:26 AM   #6 (permalink)
Default no no
No, my BOOST CONTROL VALVE(apexi), which is part of the boost contoller is hooked to the regulator. As the boost rises, so does the fuel pressure.
Old 01-16-2009, 12:29 AM   #7 (permalink)
Okay i think im explaining this wrong. I'll se if i can get a picture of it!
Old 01-29-2009, 10:24 PM   #8 (permalink)
Default Fixed
The apexi boost control valve (THAT FEEDS INTO MY FUEL PRESSURE REGULATOR) is set-up to control the boost when the nitrous is on.
And I found a massive exhaust leak.
Page generated in 0.14664 seconds with 13 queries
