Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Technical Discussion > Technical Tuning & EFI/EMS Electronics > Electronic Boost Controllers & Turbo Timers
Old 10-11-2007, 09:18 PM   #1 (permalink)
$PK$'s Avatar
Member Number: 47676
Default Map Voltage and boost chart
The link in the sticky is not working.
Can someone please post that chart that shows the map voltages and boost levels for stock and staged pcms. I just bought a mapclamp and I want to check it out. Thanks
401whp 419wtq on pump gas tuned by Jannetty Racing Enterprise
$PK$ is offline   Reply With Quote
Old 10-12-2007, 07:42 AM   #2 (permalink)
$PK$'s Avatar
Im talking about the graph that shows the stock/stage 1 pcm boost/voltage as well as the stage 2/stage 3 pcm boost/voltage. Its the one that is stickied but for some reason the link is not working.
Old 10-12-2007, 10:24 AM   #3 (permalink)
Technical Tuning & EFI/EMS Electronics moderator
sour kraut's Avatar
Member Number: 19796
go to post #14 in that post. There's a copy of the graph.
edit: oh hell, here you go.
sour kraut is offline   Reply With Quote
Old 10-12-2007, 06:58 PM   #4 (permalink)
$PK$'s Avatar
when i click on the sticky link, it says this thread is invalid. Contact the administrator.
Old 10-12-2007, 08:46 PM   #5 (permalink)
Turbolag87's Avatar
Member Number: 6491
that cant be right as im clamped at 4.28v and my map shows me 13.6psi
F&F Stage III 47lb turbo
Returnline
AGP WGA,
11.40@125mph 26psi and no boost leak
371whp @22 psi pump gas ( With a big ass boost leak)
Turbolag87 is online now   Reply With Quote
Old 10-14-2007, 04:02 PM   #6 (permalink)
jhempstead's Avatar
Member Number: 30284
The graph that sour krout posted is for 2 bar. Our cars come with a 2.25 bar sensor.
jhempstead is offline   Reply With Quote
Old 10-15-2007, 10:20 AM   #7 (permalink)
sour kraut's Avatar
yep, sorry. The original graph was updated to the 2.25 bar after that one was created. I don't know if I can find the corrected one or not. Good catch .
Old 10-15-2007, 10:24 AM   #8 (permalink)
sour kraut's Avatar
The first post tells you how to calculate it, you don't need the graph, just a calculator.
Old 10-17-2007, 03:42 PM   #9 (permalink)
Member Number: 57999
here, for the lazies that dont like to calculate...
i really see no importance in this chart tho. tune by KR and timing. at one point, according to the graph, my car only saw 7psi of boost due to my clamping. didnt tell me anything important for my sake of tuning... just something that i could say 'oh cool, im clamped to xxpsi'
christian? is offline   Reply With Quote
Old 10-19-2007, 09:25 AM   #10 (permalink)
xtrm4's Avatar
Member Number: 38360
it sucks that a 3bar map wont work on s0-s1. I'm maxing my little 2bar map the f'ck out!!! LOL
04' Dodge SRT4- modded 93' Ford Cobra- stock 94' Honda Civic- modded
PIZZA BOY
thats nothing, i floored it one day and the boost pegged infinity and i actually traveled a full week into the future...
xtrm4 is offline   Reply With Quote
Old 10-19-2007, 01:48 PM   #11 (permalink)
sure you can..its called SCT.
and whats wrong w/ the stock sensors? i had mine clamped down at one point, to the high 2.8-2.9v range. no ill effects.
Old 10-19-2007, 05:23 PM   #12 (permalink)
Turbolag87's Avatar
Member Number: 6491
How much timing and KR were you seeing? and what fuel were u using not to get knock?
Old 10-20-2007, 10:45 PM   #13 (permalink)
low 40's. 0KR.
91oct cali gas.
now w/ a different tune, my car does 39*, and does 30-33 at redline. 0kr
650cc injectors. all in the tune. pretty much
Old 10-21-2007, 06:35 PM   #14 (permalink)
Member Number: 45296
Trader Rating: (21)
could my map sensor be bad when my car is off but in the run position and the voltage is reading .10-.15 with the car off???? i have a small crack in the sensor and im thinking its bad cause of the crack...
2000 Neon ES but on this forum ;-)
lvlistchif is offline   Reply With Quote
Old 10-21-2007, 06:51 PM   #15 (permalink)
Turbolag87's Avatar
Member Number: 6491
low 40's. 0KR.
91oct cali gas.
give me an example of your timing map through the RPM's ? that would help me out. Im also getting 33deg of timing at redline but below that its starting at mid 20s and slowly goes up.
