Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Technical Discussion > Technical Tuning & EFI/EMS Electronics > Electronic Boost Controllers & Turbo Timers
Old 10-23-2009, 06:43 PM   #1 (permalink)
Member Number: 75324
Default Here's my dilema
Ok so the engine light went on due to the god damn gas cap, I the signal from the gas cap has gone out or something therefore
I believe that the ECU has turned down the turbo due to the engine light being on.
My question is how do i override the ECU to keep the boost up again?
Cause there's nothing wrong with the car just the gas cap..
03neonsrt4 is offline   Reply With Quote
Old 11-11-2009, 03:19 PM   #2 (permalink)
4drsportscar's Avatar
Member Number: 13792
disconect the negative battery cable for a min. Then you need to check for codes.
AGP hot and cold ic pipes, Needswings v6 dp, mccord plate, Auto meter EGT and wide band, Magnaflow ext,BFMIC,AGP dog bones and trans mount, AGP wast gate,S1, WOT box, DSP.
4drsportscar is offline   Reply With Quote
Old 11-13-2009, 04:52 PM   #3 (permalink)
Member Number: 31650
or just remove fuse 21 that will reset the pcm
and your radio will not be deprogram
Not stock anymore
Page generated in 0.11377 seconds with 13 queries
