dtec fcbc boost map
what is everyone's settings for the bc with a big turbo?
I'm getting brutal lag, and it's almost appearing as if the bc is doing nothing. I get way better responce from my mbc.
I have the vac lines hooked up as per the dtec manual, with a vac line going to both wga ports.
I haven't played with it too much, but I did turn the duty up to 90%, and that did nothing, I also upped the spool threshold a couple percent, but that doesn't seem to make much difference either.
100% stock engine, stock head, cams, blah blah blah
1st srt in Canada to get kicked off the track
