Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Technical Discussion > Technical Tuning & EFI/EMS Electronics > Electronic Boost Controllers & Turbo Timers
Old 05-27-2008, 03:55 PM   #16 (permalink)
Buy/Sell section Moderator
dojaman666's Avatar
Member Number: 3804
Trader Rating: (33)
Turbo XS has the manual online....
Quote: Originally Posted by thepowertowin View Post
For a moderator, you're a dick and don't support the very forum that you work with.
All items for sale will use the proper format.
If you have any questions please see here:
http://www.srtforums.com/forums/f27/...elines-352468/
dojaman666 is offline   Reply With Quote
Old 05-27-2008, 04:25 PM   #17 (permalink)
Freaky's Avatar
Member Number: 47525
thanks i figured it out . i was looking for gear set but i had togo thru inj. duty to get there . thanks for the help.
stage0,cca bfmic, needswings dp no cat, mccord electric opener , agp wga ,dtec fc/bc , front an rear strut bars ,progress front an rear sway bars an springs, tripple pillar pod with auto meter volt an oil pressure guage , turbo xs wideband, turbonetics cold side pipe raptor bov , aem cai,return line ,255 walboro fuel pump, Granatelli wires , 4306 plugs
Freaky is offline   Reply With Quote
Old 05-27-2008, 07:18 PM   #18 (permalink)
s4acr3's Avatar
Member Number: 53848
Trader Rating: (10)
Never got the thing figured out at all. Now just running another MBC. The EBC portion of the Dtec NEVER worked. only boosted to 10psi. which was the spring rate. It had power and read vac. Just never controlled the boostie. To me I would have been pissed spending $300 on a worthless upgrade that was the Lose... Glad it wasn't my money.
s4acr3 is offline   Reply With Quote
Old 05-27-2008, 07:28 PM   #19 (permalink)
Freaky's Avatar
i got an agp wga i turned it down tonight all the way till it jiggled then snugged it up . i had to mess with the gain an i got it to boost again right, it just took some time an alot of pulls either it was to much or not enough. it's hard to drive an adjust it . i do have one problem with it i'm still boosting to hard in 1st an 2nd. but the spring in my waste gate won't let it go lower than 12 . had the same problem with the greddy. i was told to try the stock one again an it should be ok i just hope it will be able to hold 18-20 psi . i guess i will see .i plan on trying the stock wga maybe thursday but i think it's gonna be realy nice once i get it figured out. gear dependant boost ftmfw ... i hope lol
Old 05-30-2008, 10:52 PM   #20 (permalink)
The Shadow's Avatar
Member Number: 18886
How much gain did you have to run?
11.09 @ 132.38mph MB's fastest FWD
The Shadow is offline   Reply With Quote
Old 05-31-2008, 12:04 AM   #21 (permalink)
Freaky's Avatar
i think i'm set between 40-45 depends on which gear . my dtec is set to gear dependant boost
Old 06-03-2008, 05:52 PM   #22 (permalink)
03ACR's Avatar
Member Number: 59357
this DTEC you guys are talking about is it the "Turbo XS DTEC boost controller pro" (DTEC-BC-PRO) thats $484.95 from Need Wings.com
-Gameboy Advance SP
i was just looking at these on there site and was wondering if they where any good but by what you guys are saying they are a pain in the ass!
Is any one having any luck with these things??
2003 E-blue srt-4 Stg3r w/toys// clutch masters stg4//dss axles// xs BFMIC// hard pipes// 62mm Tb// mopar catback// mopar STS//
personal best ET- 12.3 @ 113.4
personal best MPH- 115
-1980 dodge pick-up 4x4 on 44" w/ 671 blowen 426ci
03ACR is offline   Reply With Quote
Old 06-03-2008, 10:44 PM   #23 (permalink)
s4acr3's Avatar
Trader Rating: (10)
-Gameboy Advance SP
As far as the tuner and fuel controller portion of it, the thing is a joy to work with and would recommend it to anyone looking to tune. For the BC side of it, I wouldn't spend my money on it
Old 06-04-2008, 03:25 PM   #24 (permalink)
Freaky's Avatar
does anybody have a problem with the dtec bc not reading the same as the other boost guage . i know i got a boost leak i need to fix .
Page generated in 0.26002 seconds with 11 queries
