I need a good boost map for the dtec. For some reason it's only boosting 10psi.
I set the parameters by rpm but still didn't work. Anyone with a quick walk through on setup?
Ok, so it is boosting to 12psi. But that is what the spring in the wga is set for. So it is not even working. Period... Anyone? Nobody has a dtec boost controller?
The FcBc is setup per the diagram provided by Xs. This car had the fuel controller and tuner installed previously and came back and wanted the boost controller upgraded. So we sent out the brain and Xs reprogrammed it and sent back all the necessary parts needed for the upgrade. We installed. and, nothing happens. Gauge on gameboy reading -20.6 @ idle, and under boost. Trying to figure out what gives. I personally disassembled the fucker and reassembled it per the book and still the same. Not boosting.
My bad, yes it did. I had to have a looksie at that manual. Where exactly did you tie yours into. I tied mine in at the first group of lines going into the TB. Maybe I should tie it into the spacer?
spacer would work. basically anywhere you can get vac and pressure.
i can give you mine, it might be a good place to start.....
All items for sale will use the following format & MUST include pictures:
Name: (FIRST & LAST)
Contact: (VALID EMAIL OR PHONE #)
Price:
Description:
If you have any questions please see here: http://www.srtforums.com/forums/f27/...elines-352468/
i hooked mine up for gear dependant boost , now i can't figure out how to get to the screen to set it up . anybody have a clue?i can use the different maps indavidualy (can't spell very good ) but i can't find the set up part to make it work gear dependant . help
You have to set it (calibrate) it for each gear......
i understand that but how do you do that ? i have the maps where i want them what do you do to make it work like that ? is there a screen that you choose or do you hit a button when your in each gear to activate them ? sorry to sound stupied but i just don't know .
