Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Technical Discussion > Technical Tuning & EFI/EMS Electronics > Electronic Boost Controllers & Turbo Timers
Old 04-18-2008, 02:04 PM   #1 (permalink)
s4acr3's Avatar
Member Number: 53848
Trader Rating: (10)
Default Dtec FcBc
I need a good boost map for the dtec. For some reason it's only boosting 10psi.
I set the parameters by rpm but still didn't work. Anyone with a quick walk through on setup?
s4acr3 is offline   Reply With Quote
Old 04-21-2008, 11:58 AM   #2 (permalink)
s4acr3's Avatar
Trader Rating: (10)
Ok, so it is boosting to 12psi. But that is what the spring in the wga is set for. So it is not even working. Period... Anyone? Nobody has a dtec boost controller?
Old 04-21-2008, 11:59 AM   #3 (permalink)
NoisufnoC's Avatar
Member Number: 136
what's your setup?
omgz!! i haz mods!!
Old 04-21-2008, 10:27 PM   #4 (permalink)
s4acr3's Avatar
Trader Rating: (10)
Quote: Originally Posted by NoisufnoC View Post
what's your setup?
The FcBc is setup per the diagram provided by Xs. This car had the fuel controller and tuner installed previously and came back and wanted the boost controller upgraded. So we sent out the brain and Xs reprogrammed it and sent back all the necessary parts needed for the upgrade. We installed. and, nothing happens. Gauge on gameboy reading -20.6 @ idle, and under boost. Trying to figure out what gives. I personally disassembled the fucker and reassembled it per the book and still the same. Not boosting.
Old 04-22-2008, 08:24 AM   #5 (permalink)
NoisufnoC's Avatar
Member Number: 136
do you have the TXS MAP sensor hooked up?
Old 04-22-2008, 10:13 AM   #6 (permalink)
s4acr3's Avatar
Trader Rating: (10)
No. I am using the factory map sensor. It didn't come with one from Xs. Should it have?
Old 04-22-2008, 10:32 AM   #7 (permalink)
s4acr3's Avatar
Trader Rating: (10)
My bad, yes it did. I had to have a looksie at that manual. Where exactly did you tie yours into. I tied mine in at the first group of lines going into the TB. Maybe I should tie it into the spacer?
Old 04-22-2008, 01:04 PM   #8 (permalink)
NoisufnoC's Avatar
Member Number: 136
spacer would work. basically anywhere you can get vac and pressure.
Old 04-23-2008, 10:01 AM   #9 (permalink)
s4acr3's Avatar
Trader Rating: (10)
Still nothing. Looks like $300 wasted so far...
Old 05-11-2008, 11:22 PM   #10 (permalink)
can't stop spinning's Avatar
Member Number: 9183
any luck yet? I'm having the exact same problem you're having.
100% stock engine, stock head, cams, blah blah blah
1st srt in Canada to get kicked off the track
can't stop spinning is offline   Reply With Quote
Old 05-13-2008, 11:14 AM   #11 (permalink)
Elected Moderator
dojaman666's Avatar
Member Number: 3804
Trader Rating: (35)
i can give you mine, it might be a good place to start.....
All items for sale will use the following format & MUST include pictures:
Name: (FIRST & LAST)
Contact: (VALID EMAIL OR PHONE #)
Price:
Description:
If you have any questions please see here:
http://www.srtforums.com/forums/f27/...elines-352468/
dojaman666 is offline   Reply With Quote
Old 05-27-2008, 03:13 PM   #12 (permalink)
Freaky's Avatar
Member Number: 47525
i hooked mine up for gear dependant boost , now i can't figure out how to get to the screen to set it up . anybody have a clue?i can use the different maps indavidualy (can't spell very good ) but i can't find the set up part to make it work gear dependant . help
stage0,cca bfmic, needswings dp no cat, mccord electric opener , agp wga ,dtec fc/bc , front an rear strut bars ,progress front an rear sway bars an springs, tripple pillar pod with auto meter volt an oil pressure guage , turbo xs wideband, turbonetics cold side pipe raptor bov , aem cai,return line ,255 walboro fuel pump, Granatelli wires , 4306 plugs
Freaky is offline   Reply With Quote
Old 05-27-2008, 03:34 PM   #13 (permalink)
Elected Moderator
dojaman666's Avatar
Member Number: 3804
Trader Rating: (35)
You have to set it (calibrate) it for each gear......
Old 05-27-2008, 03:38 PM   #14 (permalink)
Freaky's Avatar
i understand that but how do you do that ? i have the maps where i want them what do you do to make it work like that ? is there a screen that you choose or do you hit a button when your in each gear to activate them ? sorry to sound stupied but i just don't know .
Old 05-27-2008, 03:49 PM   #15 (permalink)
Elected Moderator
dojaman666's Avatar
Member Number: 3804
Trader Rating: (35)
There is a calibration menu.
