DTEC BC Guru's..
I'll try to explain this the best I can without pictures / video..
I recently got a DTEC FC/BC. Fuel Controller works like a champ and have had no issues with it. BC on the other hand is a bit more difficult.
We got it setup so it reads vacuum close to what the gauge is seeing. Around -10 Vac it starts reading wrong. Anytime after that it will read in vacuum even if the car is in boost.
BC is calibrated to the little sheet/tag they was recieved when I bought it.
Car has S3 external wastegate with vacuum lines routed per TurboXS's install instructions.
Could really use some help..
Sony Alpha700
Minolta 50mm f1.7
Minolta 70-210mm f4
Minolta 28mm f2.8
Carl Zeiss 24-70mm f2.8
