Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Technical Discussion > Technical Tuning & EFI/EMS Electronics > Electronic Boost Controllers & Turbo Timers
Old 10-13-2008, 11:28 AM   #1 (permalink)
NoisufnoC's Avatar
Member Number: 136
Default DTEC BC Clicking Solenoid
So I woke up this morning to find the boost solenoid from the DTEC BC clicking. It sounded like a relay clicking on and off. This was happening while the car was not running.
It boosted fine a few days ago.
On the way to work I got on it a few times and it boosted normal.
Is this anything to worry about?
Keeping the tire companies in business...
...one WOT shift at a time™
|| Mod List Coming Soon ||
***Forum Rules***
Old 10-13-2008, 02:56 PM   #2 (permalink)
NoisufnoC's Avatar
Member Number: 136
anyone? anyone?
Old 10-13-2008, 07:24 PM   #3 (permalink)
NoisufnoC's Avatar
Member Number: 136
boost pressure and spool is completely normal, still clicking!!
Old 10-14-2008, 10:07 AM   #4 (permalink)
NoisufnoC's Avatar
Member Number: 136
i disconnected the negative terminal overnight. no change. still clicking!!
Old 10-14-2008, 10:11 AM   #5 (permalink)
aaronneon@RealTune's Avatar
Member Number: 623
Trader Rating: (432)
Hmm. Check the ground for the solenoid. Havent had one due this that I can remember
www.Realtuned.com
Each car built/tuned/track prepped in house
{9.87@149 Erabbit23 build}{9.96@146 Fred@Realtune build}{9.98@144 Squishy332000 build}{10.62@138 Karkraft build}{10.80@127 Mezturbo4 build}{10.88@129 90VNT build}{10.97@136 srt4me18 build}
{11.62@128 Realtune Caliber}{11.85@119 Whoosh@Realtune Caliber}
Home of the Worlds Quickest/Fastest CSRT-4, Manual NSRT4, and Stock turbo SRT4
Old 10-14-2008, 10:12 AM   #6 (permalink)
NoisufnoC's Avatar
Member Number: 136
i was just thinking that, i'll check it out tonight. thanks man.
Old 10-15-2008, 12:32 AM   #7 (permalink)
NoisufnoC's Avatar
Member Number: 136
i think i figured it out.
a while back i noticed the the map sensor reading was showing almost -1 PSI of boost when the car was off. I did some reading in the DTEC manual and found a setting that you can use to calibrate the sensor. Basically you're telling it where zero is. I had added 1.2PSI of correction to get the map reading to be 0 when the car was off.
I noticed tonight that my map reading was bouncing around between +.2psi and +.6psi with the car off. This was enough to trigger the solenoid to go to 99% duty cycle, but then when the pressure would drop it would go to 0% duty. That was what was making the clicking.
For the time being i've zeroed out the correction factor, which has my map reading about -.4psi or so with the car off.
this explains why the car drove fine, because with the car running it was pulling vacuum.
i'll follow up in the morning and make sure this fixed it, but i'm pretty confident after looking through the DTEC settings and gauges that i've found the problem.
Old 10-15-2008, 09:46 AM   #8 (permalink)
NoisufnoC's Avatar
Member Number: 136
seems like that fixed it!
Page generated in 0.15452 seconds with 13 queries
