You mean a line off the boost source to the fuel pressure regulator? You can t into pretty much any line that doesn't see vacuum...I have mine run off of the coldside hard pipe
yea i know that but what does the bc need to have a line tapped into the fuel reg for??
The return line uses a rising rate fuel pressure regulator...when you hook it to a boost source it will increase fuel pressure as the boost pressure increases. It is usually a 1:1 ratio
I'll try to find a better explanation of how it works...I don't really know how to explain it clearly
fuel mods are an agp return line (60psi), 255 walbro, stock injectors, i dont have a dtec yet and still have stg 0 (stg 1 on the way) so i've gotta mapclamp
That is the problem with the mapclamp...you don't have the ability to tune as the rpms change. It only allows you to set the map voltage at 1 setting.
I bet getting the dtec will solve your most of your problems with the irregular afrs though
I have only messed with my car, and I never played with anything (fuel/boost) when it was stock, I went from stock w/ exhaust & intercooler to big turbo
I wish I could help you out more. If I were you I wouldn't mess with it to much if it is safe, I would wait on the dtec
