16 psi would be 1.1 bar. 21 psi is 1.5 bar. so somewhere inbetween there would probably be fine for you. your gain is probably set up too high. that can cause an overboost. are you boosting by gear? you can change duty cycle and boost by gear, there's a write up for base settings on this site somewhere, it was very helpful.
