Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Technical Discussion > Technical Tuning & EFI/EMS Electronics > Electronic Boost Controllers & Turbo Timers
Old 10-29-2008, 03:43 PM   #1 (permalink)
fast2thegas's Avatar
Member Number: 13357
Default Avc-r probs
my avc-r keeps overboostin.... i've double checked the vacc lines all hooked up the way describe in the instructions.... turned the learn and boost by gear off and even set the duty cylce down to 35%... i have a 60-1 so its on a big turbo.... anybody with a big turbo have any ideas?? it has a nipple on the NO side of the solenoid valve instead of orifice like described in the instructions could this be the problem....bought it from a friend and have no clue wat an orifice even is????
fast2thegas is offline   Reply With Quote
Old 10-29-2008, 03:50 PM   #2 (permalink)
bpsrt4's Avatar
Member Number: 40796
Trader Rating: (29)
So it is going of your target boost?
Turn the duty cycle down till it hits and stays where you want it
Here is the manual: http://www.apexi-usa.com/pdf/product...tation/200.pdf
bpsrt4 is offline   Reply With Quote
Old 10-29-2008, 03:55 PM   #3 (permalink)
no its not hittin the target boost...i've turned all the way down to 20% and still the same results.....overboostin got to let out of it cause it boost so high
Old 10-29-2008, 04:02 PM   #4 (permalink)
bpsrt4's Avatar
Trader Rating: (29)
Sorry I meant to say its going over the target boost.
Try turning the boost controller off and see where you end up
Old 10-29-2008, 04:18 PM   #5 (permalink)
turned it off and it still 20psi
Old 10-29-2008, 07:43 PM   #6 (permalink)
bpsrt4's Avatar
Trader Rating: (29)
So...you might have your vac lines mixed up.
Try running a line from the nipple on the turbo to the bottom port on the wg and see if you still hit 20 psi. If you do you may want to get a different wg spring.
Old 10-29-2008, 07:58 PM   #7 (permalink)
i have the avc-r t'd into the line runnin from the wastegate to the turbo nipple.... u want me to run a straight vaccum from the turbo to the bottom of the wastegate?
Old 10-29-2008, 08:00 PM   #8 (permalink)
bpsrt4's Avatar
Trader Rating: (29)
Yup...this will tell you how strong the spring in the wg is.
How do you have you vacuum lines run as it sits right now?
Old 10-30-2008, 01:38 PM   #9 (permalink)
bottom of wastegate ran into the turbo nipple t'd off into NC port, Com port to top of wastegate and NO port just has a nipple on it
Old 10-30-2008, 02:07 PM   #10 (permalink)
bpsrt4's Avatar
Trader Rating: (29)
The vac lines are routed properly...there is no leaks in any of the lines right?
It may be the spring in the waste gate...I can't really think of another problem right now
Old 10-30-2008, 03:49 PM   #11 (permalink)
nope no leaks in the lines.... i just wonder if the NO port with just the nipple on it is just letting it leak.....suppose to have an orifice but i dont know wat that is???? anybody got a pic??????
Old 10-30-2008, 03:55 PM   #12 (permalink)
bpsrt4's Avatar
Trader Rating: (29)
I have mine set-up for an internal gate, but on the port I'm not using I just have a nipple on there.
Old 10-30-2008, 07:26 PM   #13 (permalink)
turbojack's Avatar
Member Number: 11814
Trader Rating: (122)
In this link it looks like someone cleaned up the factory manual. May be good for you as a reference.
AVC-R Printable
As for the one open port referenced as connecting to an orifice.......this just a vent. take a look at some of the stock solenoids (forgot off hand which one) and you will see it has a little filter but no line hooked up. What ApeXi is looking for you to do is to run a line to a clean spot someplace where dirt and water can not enter into the solenoid and screw it up. You could also get a brass sintered filter (also called a muffler) like the ones supplied with the MAC valve solenoids that the AEM boost sensor uses.
Here's an image of a brass sintered filter
If looking to get a filter you pretty much only need to know the thread size and pitch of female ports in the solenoid or take one of the supplied brass fittings and use that for reference when purchasing.
turbojack is online now   Reply With Quote
Page generated in 0.21567 seconds with 13 queries
