AVC-R not regulating boost with tial ewg, .50 trim turbo
i have all the vac lines hooked up properly the avc-r shows real time boost psi to exactally what the stock boost gauge is showing, all volts on solenoids or sensors are good! im almost positive i have all the settings correct on the avc-r as well, went through those like a million times lol and tried all different types of ways to change the boost so it would either regulate it under the tial wastegate springs or above their ratings that are in my wastegate... with no boost controller in at all and a vac line ran right from the turbo to the side port on the ewg it will run about 16 psi..... 1.10 was the max replay top hold showing on the avc-r so that is almost right on as well but still no change while the boost soleniod is hooked up it will just way over boost any setting i put into the avc-r including duty cycle % either way lol.... and a rough over boost usually goes to around 25 psi or so... so definitally not good but cant tell much past that cause the stock gauge only really goes to 20 so its just a rough estimate... any idea and if so please send pics or something cause this is a pain..... thanks!
