Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Technical Discussion > Technical Tuning & EFI/EMS Electronics > Electronic Boost Controllers & Turbo Timers
Old 02-19-2009, 05:24 PM   #1 (permalink)
Member Number: 58658
Question AVC-R gear specific/traction controll?
I have and love the avc-r. recently i went to an ATP GT30R kit (418whp 451ft lbs TQ 22psi on 91 pump woot!) and i have huge traction issues in 2nd and 3rd gear. I have the target boost/duty set correct, and the gear judge values are correct, how do i use gear learn and/or start duty to decrease boost/duty in specific gears? I know i can use the rpm based boost/duty graph but that will effect 4th and 5th which i don't want. PLEASE help ANY would be greatly appreciated!!
fightingirish is offline   Reply With Quote
Old 03-25-2009, 09:50 PM   #2 (permalink)
Member Number: 31650
i will have to confirm on my gage i`m not sure about the exact menu
first you remove the learning function,because it try`s to learn in every gear...no good)
the best i have found is set your correct boost in 4 gear
after that you play in ....(sorry forgot menu) and put some - value in the gear you want to drop boost
i think it`s starting boost or somthing like that
Not stock anymore
Page generated in 0.15396 seconds with 13 queries
