Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Technical Discussion > Technical Tuning & EFI/EMS Electronics > Electronic Boost Controllers & Turbo Timers
Old 05-21-2008, 05:03 PM   #16 (permalink)
Member Number: 64119
u have to have a toggle switch in order to use it.
pretty much runs a certain amount of boost for a preset amount of time.
not sure what much use it is.
ill make a how to on the whole avcr soon. the 1 thats avail. didnt help me much
Santiago. is offline   Reply With Quote
Old 05-21-2008, 05:59 PM   #17 (permalink)
dirtyd99's Avatar
Member Number: 38128
yeh i know about the toggle switch. the how to is just somthing to get you started in my opinion. i used it and it came out fine minus the super slow spool i had. it took me a while to figure it out.
60ft: 2.4 - 1/4: 13.2 on DR's
dirtyd99 is offline   Reply With Quote
Old 06-22-2008, 05:42 PM   #18 (permalink)
Member Number: 60091
Default Greddy Full Auto Turbo Timer
Quote: Originally Posted by NIVO88T View Post
Ok, guys stop cluttering the Tuning forums with EBC and Turbo Timer questions and post here!
CAN YOU PLEASE HELP WITH A DIAGRAM TO HOOK THIS UP TO MY SONS 03 SRT4
scottnoluck is offline   Reply With Quote
Old 07-19-2008, 04:19 PM   #19 (permalink)
Member Number: 51032
Speaking of super slow spool. I have my EBC connected correctly. my Gain is 68% my set is at 35% my SetGain is at 66% and my turbo takes forever to spool. I could be at 3.5k rmp in second step on and it there is still lots of lag its a small turbo this bad boy should spool up quick SuperStocker from RIPP. any ideas?
BollYizzo! is offline   Reply With Quote
Old 07-20-2008, 07:21 PM   #20 (permalink)
dirtyd99's Avatar
sounds like you are using the greddy ebc. if so then i cant help you there bro. sombody will chime in eventually.
Old 09-26-2008, 11:09 AM   #21 (permalink)
Member Number: 50702
I'm also looking for a nominal setup on my EBC, running S2. I don't want anything crazy. I want the turbo to spool up quick, however I want to limit the possibility of overboost. Probably going to call Greddy as soon as tech support opens and see if they got some numbers for me based off the PSI I want to run in LO and HI.
HavocSRT is offline   Reply With Quote
Old 09-26-2008, 12:58 PM   #22 (permalink)
Here is the information I found from calling the Greddy Tech in Irvine.
(9495888300)
Note they don't have specifics for our cars so won't be able to recommend nominal numbers, you will have to determine these.
Also note, I am in the process of trying to unscrew my own issues with (overboosting).
We started with LO mode, told him I wanted 16 PSI, he told me to set my START at -2 to -1.5 of that target PSI as a good place to start my tuning. To close/high on the START will turn into Boost Spike. Which I'm guessing is that ramp up in Boost or Surging the car will do... which I also think leads to Overboosting but hey I might not know what I'm talking about just yet as I tinker with it.
Also he said to put my SET at 10% and add 5% until I am reaching my target pressure levels. I'm supposing I will have to feel this out but basically the way I understand it, the SET is how much work my turbo is doing to reach my START or target 16 PSI. So if 10% sees me making only 8 PSI, start climbing 5% and rechecking what numbers I get.
As far as GAIN goes, this affects Boost Creep and Fall Off, basically when I hit 16 does it start going 16.1, 16.2, or 15.9, 15.8, etc. He said to start with 5% and work my way up to 1% increments until I eliminate either of these predicaments. Obviously I want a static number.
WARNING set for whatever peak boost value you want a notification on (red screen flash). I guess if I wanted 18 to be my max in HI mode then I might go for 18 and change here.
LIMITER Subtracts a % of your SET when you hit your WARNING. Usually tuners with low boost go with 20% and high boost applications go with 30%. I'd imagine our cars fall into 20 or the middle (25) for optimal settings.
Note also, I am aiming for what I think is conservative... I remember my SRT stock being like 14 PSI so I figure 16 PSI on daily driving is probably the way to go with my S2 and other BS mods. 18 PSI is something I might want to kick it up to if I am getting competitive on the road. I may go for a 15/17, even more conservative model until I figure out what I am doing.
Anyone with more info or who wants to critique this, please contribute.
And Boll, you probably should just take it back to square 1 like the tech suggested to me and retune it. I know its going to be a PIA and be a few runs to get it at least somewhat properly situated but write down where you go from the beginning and all should be good.
I'll further report any findings.
Old 10-12-2008, 04:02 PM   #23 (permalink)
Member Number: 33399
Trader Rating: (20)
Default E-boost2 HOW-TO
ANYONE PLEASE PROVIDE LINK TO,
HOW-TO INSTALL TURBOSMART E-boost2
THANKS TO ALL IN ADVANCE !
KLZE is offline   Reply With Quote
Old 10-19-2008, 08:47 PM   #24 (permalink)
MidnightRacerSRT4's Avatar
Member Number: 47098
Trader Rating: (12)
ok i've asked like 4 times in the request how to section and no one will even answer me with a "i have no idea" so i might as well ask here... does anyone have a how-to on installing the Greddy E-01 with the external signal harness and what not... or better yet just let me know where the wires go and i will figure it out from there... anything will help.
thanx
Justin
i like boobies
MidnightRacerSRT4 is offline   Reply With Quote
Old 10-31-2008, 10:18 AM   #25 (permalink)
Member Number: 58658
I have a AVC-R and recently switched from the stock WGA to the ATP 30R kit and external wastegate. I DESPERATELY need to know how to re-route the vacuum lines to go from internal to external WG. Also, my 30R compressor housing isn't vacuum tapped, so i am curious if i can get vacuum source from my cold side charge pipe or does it HAVE to come from the compressor housing? PLEASE HELP!
fightingirish is offline   Reply With Quote
Old 01-08-2009, 09:21 PM   #26 (permalink)
Matts04SRT's Avatar
Member Number: 58076
Does anyone have a how to wire a AVCR, I have looked all over and, can't find how to wire it in, and what to wire it into, I have a Neo w/ tach driver and I know that I need to wire into that but what wires from the tach driver. Any help please, I already have the How to, to set it up, just need to know how is the best way to wire in everything and into what.
Thanks
Matts04SRT is offline   Reply With Quote
Old 01-09-2009, 04:25 PM   #27 (permalink)
turbojack's Avatar
Member Number: 11814
Trader Rating: (122)
Thanks
Tach/RPM hookup
PCM connection
Overview wiring
Some helpful links
AVC-R Printable
Installing APEXi AVCR - Page 1
Looking at AVC-R, advise...please
how to set vac lines up w/ AVCR for ext. WG, and other ?'s
AVC-R issues
HOW-TO: A'PEXi AVC-R EBC & MSD Tach Driver Install
Boost controllers and wga's basics (how they work together)
HOW TO: Apexi Avc-R Boost Contoller Setup!!
JSC Speed Project Dodge SRT-4: Apexi AVCR Boost Controller
AVC-R Boost by gear - Honda-Tech
turbojack is online now   Reply With Quote
Old 01-09-2009, 04:45 PM   #28 (permalink)
Matts04SRT's Avatar
Sweet thanks a whole bunch
Old 01-13-2009, 09:30 AM   #29 (permalink)
goblin42's Avatar
Member Number: 63198
Default AEM TruBoost ???s
okay so i installed my AEM EBC this weekend.
AEM doesnt give very detailed instructions.
I took out the green line into boost silinoid and black line out of boost silinoid to WGA.
i know there are three ports on the silinoid and i have it set for "internal wastegate" so since i only have a stage 2 kit, i'm assuming that's correct.
i'm getting a sputtering air sound when i boost so i'm thinking i might have these hoses not connected right.
as for where they were on the vac harness, do i leave those open or plug them?
goblin42 is offline   Reply With Quote
Old 01-14-2009, 09:55 AM   #30 (permalink)
I'm not personally familiar with the AEM EBC and will be honest, I had a professional tuner do the install on my PROFEC. Your note about the "sputtering" is of interest though. Where is this sputtering coming from and what conditions cause it? Is it non-stop?
My car has some sputtering too (located at the turbo) but I've never seen this as a huge problem as it is conditional. Sputtering happens if I'm boosting but boosting low... low as in the increase (gain?) isn't accruing fast enough and this is mostly in how much I gas it at the pedal. If I go for WOT, no sputtering what-so-ever. Normal stop and go driving, I will get some sputter but only if I try to pick it up a little and half-ass it at the pedal. That being said, I think adjusting your gain on your AEM, if it has such a setting, might help. You will have to play with it a bit. You should have some sort of factory default settings and some increments to tune to within the documentation, I say this because that is what Greddy provides and I'm mostly happy with the tune on my EBC for now.
Any other sputtering from any other location could be turbo blowback I suppose through the air intake? Still unsure what you meant by sputtering and if my experience even applies to the problem you are having.
Page generated in 0.23615 seconds with 13 queries
