Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Technical Discussion > Technical Tuning & EFI/EMS Electronics > Electronic Boost Controllers & Turbo Timers
Old 05-21-2008, 04:03 PM   #16 (permalink)
Member Number: 64119
u have to have a toggle switch in order to use it.
pretty much runs a certain amount of boost for a preset amount of time.
not sure what much use it is.
ill make a how to on the whole avcr soon. the 1 thats avail. didnt help me much
Santiago. is offline   Reply With Quote
Old 05-21-2008, 04:59 PM   #17 (permalink)
dirtyd99's Avatar
Member Number: 38128
yeh i know about the toggle switch. the how to is just somthing to get you started in my opinion. i used it and it came out fine minus the super slow spool i had. it took me a while to figure it out.
I WOT shift my lawn mower.
dirtyd99 is offline   Reply With Quote
Old 06-22-2008, 04:42 PM   #18 (permalink)
Member Number: 60091
Default Greddy Full Auto Turbo Timer
Quote: Originally Posted by NIVO88T View Post
Ok, guys stop cluttering the Tuning forums with EBC and Turbo Timer questions and post here!
CAN YOU PLEASE HELP WITH A DIAGRAM TO HOOK THIS UP TO MY SONS 03 SRT4
scottnoluck is offline   Reply With Quote
Old 07-19-2008, 03:19 PM   #19 (permalink)
Member Number: 51032
Speaking of super slow spool. I have my EBC connected correctly. my Gain is 68% my set is at 35% my SetGain is at 66% and my turbo takes forever to spool. I could be at 3.5k rmp in second step on and it there is still lots of lag its a small turbo this bad boy should spool up quick SuperStocker from RIPP. any ideas?
BollYizzo! is offline   Reply With Quote
Old 07-20-2008, 06:21 PM   #20 (permalink)
dirtyd99's Avatar
sounds like you are using the greddy ebc. if so then i cant help you there bro. sombody will chime in eventually.
Old 09-26-2008, 10:09 AM   #21 (permalink)
Member Number: 50702
I'm also looking for a nominal setup on my EBC, running S2. I don't want anything crazy. I want the turbo to spool up quick, however I want to limit the possibility of overboost. Probably going to call Greddy as soon as tech support opens and see if they got some numbers for me based off the PSI I want to run in LO and HI.
HavocSRT is offline   Reply With Quote
Old 09-26-2008, 11:58 AM   #22 (permalink)
Here is the information I found from calling the Greddy Tech in Irvine.
(9495888300)
Note they don't have specifics for our cars so won't be able to recommend nominal numbers, you will have to determine these.
Also note, I am in the process of trying to unscrew my own issues with (overboosting).
We started with LO mode, told him I wanted 16 PSI, he told me to set my START at -2 to -1.5 of that target PSI as a good place to start my tuning. To close/high on the START will turn into Boost Spike. Which I'm guessing is that ramp up in Boost or Surging the car will do... which I also think leads to Overboosting but hey I might not know what I'm talking about just yet as I tinker with it.
Also he said to put my SET at 10% and add 5% until I am reaching my target pressure levels. I'm supposing I will have to feel this out but basically the way I understand it, the SET is how much work my turbo is doing to reach my START or target 16 PSI. So if 10% sees me making only 8 PSI, start climbing 5% and rechecking what numbers I get.
As far as GAIN goes, this affects Boost Creep and Fall Off, basically when I hit 16 does it start going 16.1, 16.2, or 15.9, 15.8, etc. He said to start with 5% and work my way up to 1% increments until I eliminate either of these predicaments. Obviously I want a static number.
WARNING set for whatever peak boost value you want a notification on (red screen flash). I guess if I wanted 18 to be my max in HI mode then I might go for 18 and change here.
LIMITER Subtracts a % of your SET when you hit your WARNING. Usually tuners with low boost go with 20% and high boost applications go with 30%. I'd imagine our cars fall into 20 or the middle (25) for optimal settings.
Note also, I am aiming for what I think is conservative... I remember my SRT stock being like 14 PSI so I figure 16 PSI on daily driving is probably the way to go with my S2 and other BS mods. 18 PSI is something I might want to kick it up to if I am getting competitive on the road. I may go for a 15/17, even more conservative model until I figure out what I am doing.
Anyone with more info or who wants to critique this, please contribute.
And Boll, you probably should just take it back to square 1 like the tech suggested to me and retune it. I know its going to be a PIA and be a few runs to get it at least somewhat properly situated but write down where you go from the beginning and all should be good.
I'll further report any findings.
Page generated in 0.12296 seconds with 11 queries
