what i would like to find out is if there is any easy way to wire up an avcr if you already have an safc-2 installed. is there any way to use the same wiring for both, or do i have to run a new tach adapter and all that again?
huh?
you wire in 7 wires from the avcr...and tie into the tach adapter...not sure what your whole question is...
my question is, since the avcr and safc use some of the same wires is there an easier way to wire up one or the other if you already have one. as with my situation, i already have an safc installed. i now have an avcr that i'm considering installing and am trying to find the easiest way to do the install. also can the tach adapter that is used for the safc also be tapped into for use with the avcr.
what should i put my boost at and duty for a stock turbo i have many extras safcII aem cold air, msd, turbonetics blow off, agp waste gate electrions boost valve
