Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Technical Discussion > Technical Tuning & EFI/EMS Electronics > Electronic Boost Controllers & Turbo Timers
Old 03-31-2008, 10:15 AM   #1 (permalink)
Member Number: 62902
Default Apexi Avc-r
I just recently bought one of these and I do not know how to wire it in. Can someone please explain this to me?
Thanks,
-Dustin
DThies is offline   Reply With Quote
Old 04-05-2008, 12:49 PM   #2 (permalink)
SpeedEuphoria's Avatar
Member Number: 30870
Thanks,
-Dustin
read the manual, get the FSM to look for the wires you need
Project log pics
Old 04-06-2008, 10:37 PM   #3 (permalink)
Thanks man. Ill try that. I was starting to wonder if anyone else was on here lol. Thanks again.
Old 05-24-2008, 04:46 PM   #4 (permalink)
turbotm's Avatar
Member Number: 46751
i just got one recently but have run into the same issue i need some cliff's notes on this subject
turbotm is offline   Reply With Quote
Old 05-24-2008, 05:27 PM   #5 (permalink)
Member Number: 64119
what do you need cliffnotes on?
a detailed how-to is written on how to wire it up.
so i wont even bother with that
this thing NEEDS a tach adapter. no ifs, ands, or butts. to those that say you dont, are full of shit.
dont use ANY of the special features. makes boost totally unstable.
if you are stock turbo, sell it. it will do you nothing that a mbc cant do.
Santiago. is offline   Reply With Quote
Old 05-31-2008, 07:57 AM   #6 (permalink)
gump1114's Avatar
Member Number: 28766
what i would like to find out is if there is any easy way to wire up an avcr if you already have an safc-2 installed. is there any way to use the same wiring for both, or do i have to run a new tach adapter and all that again?
295 HP & 333 TQ - tuned by me 13.076 @ 110.14
gump1114 is offline   Reply With Quote
Old 06-01-2008, 01:12 AM   #7 (permalink)
Member Number: 64397
huh?
you wire in 7 wires from the avcr...and tie into the tach adapter...not sure what your whole question is...
DRAST1C. is offline   Reply With Quote
Old 06-01-2008, 07:29 AM   #8 (permalink)
gump1114's Avatar
Quote: Originally Posted by DRAST1C. View Post
huh?
my question is, since the avcr and safc use some of the same wires is there an easier way to wire up one or the other if you already have one. as with my situation, i already have an safc installed. i now have an avcr that i'm considering installing and am trying to find the easiest way to do the install. also can the tach adapter that is used for the safc also be tapped into for use with the avcr.
maybe that makes sense...
Old 06-01-2008, 10:04 AM   #9 (permalink)
the avcr wiring is completely independent from the safc. i run both.
the only things that will be similar is you tap the avcr into the tach adapter as well.
Old 06-28-2008, 11:46 AM   #10 (permalink)
Member Number: 36805
looking 4 some help! bought a used avc-r have no manual or anything on how to hook it up can someone help me out 05 srt john
vikingsgolf_john is offline   Reply With Quote
Old 06-28-2008, 11:01 PM   #11 (permalink)
search and DL the avc-r manual
Old 06-29-2008, 05:43 AM   #12 (permalink)
gump1114's Avatar
there is a how-to in the how to section on this forum which give detailed instructions on how to install it.
Old 07-21-2008, 08:30 PM   #13 (permalink)
Member Number: 65453
what should i put my boost at and duty for a stock turbo i have many extras safcII aem cold air, msd, turbonetics blow off, agp waste gate electrions boost valve
dontevntry is offline   Reply With Quote
Page generated in 0.23385 seconds with 11 queries
