Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Technical Discussion > Technical Tuning & EFI/EMS Electronics > Electronic Boost Controllers & Turbo Timers
Old 12-19-2008, 11:56 AM   #1 (permalink)
Member Number: 64983
Default anyone run a dual stage bc.?(turboxs)
i have a used duals stage turboxs, bu ti dont have any directions. im just not sure out of the two wires ,wich one is the hot and ground.
any help would be apretiated. thanks
garryb05srt4 is offline   Reply With Quote
Old 12-19-2008, 11:59 AM   #2 (permalink)
Slow_spool's Avatar
Member Number: 50382
Trader Rating: (33)
are both of the wires black?
i havent hooked up a turbo xs boost controller, but on many other solenoids it doesnt matter which wire is hot or ground as long as current passes through the solenoid, you can test it out on your battery if both wires are the same color
Slow_spool is offline   Reply With Quote
Old 12-19-2008, 12:04 PM   #3 (permalink)
one is pruple and the other is green. just dont want to fry somethin if i hooked it up wrong.
so im assuming the green would get grounded and the purple would go to the switch. and then hook a hot wire to the switch???
Old 12-19-2008, 12:18 PM   #4 (permalink)
Slow_spool's Avatar
Trader Rating: (33)
well dont try my idea then lulz.
did you look on turbo xs's website? they have a couple how to's on their products in pdf format there.
Old 12-19-2008, 12:28 PM   #5 (permalink)
no. that would be too easy. hahahaha thanks for pointing out what i should have done in the first place
Page generated in 0.18388 seconds with 13 queries
