Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Technical Discussion > Technical Tuning & EFI/EMS Electronics > Electronic Boost Controllers & Turbo Timers
Old 04-26-2009, 06:55 PM   #1 (permalink)
boostgurusrt's Avatar
Member Number: 70058
Default AEM Tru Boost: Help please?
Just got a new AEM Tru Boost, and I had my WG set at 19 lbs., I turned it down to let the boost solenoid take over and it's not controlling boost....it now is only spiking at 10 lbs. What would cause that to happen?
Thanks in advance.
AEM full cold air,AEM Tru Boost , Sportline lowering springs, Greddy TurboTimer,MP coil heat shield,QW BFMI, Forge Bov Dcr coolant over flow, MSDwires, FM wastegate,Map clamp, Bwoody solid mounts,TPS rewire,Ported TB
boostgurusrt is offline   Reply With Quote
Old 05-05-2009, 09:48 AM   #2 (permalink)
harvboi05's Avatar
Member Number: 30703
you probly have to jack up the duty cycle to increase boost.
for example, dont adjust setting A to 21% for 21psi, it might need 33% for 21psi. those numbers are just for my example dont just set it to 33%.
gotta play with it and see where you end up.
agp S3D 48 kit. 12.37@118.7 and 12.54@122.4.
^^car for sale!
http://www.srtforums.com/forums/f165...ate-ny-521715/
fwd = bad.
new addition: 98 cobra
harvboi05 is offline   Reply With Quote
Page generated in 0.14007 seconds with 13 queries
