Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Technical Discussion > Technical Tuning & EFI/EMS Electronics > Electronic Boost Controllers & Turbo Timers
Old 10-01-2008, 11:13 AM   #1 (permalink)
mmmmpsi's Avatar
Member Number: 61977
Trader Rating: (17)
Default 50 Trim + Greddy Boost Controller = Confusion.. Please help!
OK, so I'm really confused the more I read the more confused I get.. So I'm a picture guy and I want to know if this is correct.. HELP!
mmmmpsi is offline   Reply With Quote
Old 10-01-2008, 11:24 AM   #2 (permalink)
NeonDan's Avatar
Member Number: 138
Trader Rating: (82)
its simple man
basically you have two ports on the wastegate
top port is to control boost
bottom port is to stabilize the diaphram so you dont have boost creep
i will be back up this weekend for good.....so lmk if you need any help
Old 10-01-2008, 11:33 AM   #3 (permalink)
mmmmpsi's Avatar
Trader Rating: (17)
I have another question.. Why can't the SAFC II monitor knock??
Old 10-01-2008, 11:34 AM   #4 (permalink)
mmmmpsi's Avatar
Trader Rating: (17)
Quote: Originally Posted by NeonDan View Post
its simple man
Ok but does that mean my diagram is right?
I also found out some very good information on how the SAFC works, I guess I should read the manual hahaha..
Old 10-01-2008, 11:35 AM   #5 (permalink)
NeonDan's Avatar
Member Number: 138
Trader Rating: (82)
the signal the NGCIII uses is not in a format the SAFC can read properly. I would strongly suggest getting an Aeroforce SG....reads everything the pcm is doing
Old 10-01-2008, 11:36 AM   #6 (permalink)
NeonDan's Avatar
Member Number: 138
Trader Rating: (82)
if the diaphram had anything wrong with it you'd have some serious issues
Old 10-01-2008, 11:45 AM   #7 (permalink)
mmmmpsi's Avatar
Trader Rating: (17)
NOT my diaphram .... my PICTURE!!!! hahaha :P Is that the right way to hook it up.
You're a funny guy hehehe
Old 10-01-2008, 11:46 AM   #8 (permalink)
mmmmpsi's Avatar
Trader Rating: (17)
Yah I'm leaning more and more towards a Aeroforce over a ScanGauge II.
Old 10-01-2008, 12:24 PM   #9 (permalink)
NeonDan's Avatar
Member Number: 138
Trader Rating: (82)
was wanting to see if you were awake
there is one on the compressor cover use a tee so that one line goes to supply boost controller which then connects to the top port of wga and the other line from the tee goes to the bottom port of wga
Old 10-01-2008, 12:59 PM   #10 (permalink)
mmmmpsi's Avatar
Trader Rating: (17)
So you're saying it's right then? There was an explanation somewhere of what the COM and NC ports were I think COM = Common.
Old 10-01-2008, 08:41 PM   #11 (permalink)
mmmmpsi's Avatar
Trader Rating: (17)
bump help please...
Page generated in 0.18366 seconds with 13 queries
