Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > FTP-Racing
Old 11-07-2007, 12:33 AM   #1 (permalink)
Garrett@FTP-Racing's Avatar
Member Number: 37401
Trader Rating: (57)
Default My Hybrid Project
First off here's a link to the full thread:
Stage 2/Stage 3/ Evo Hybrid Project
It basically consists of a s3 manifold mated to a evo 8 16g6 turbo. The thread above shows the full walk through of how it all works, my modlist, and recently my last dyno.
I'll give you the short and sweet version of the car.
Complete modlist on the car:
S0 pcm
S2 injectors
PTP wga
FTP-Racing Return line
Walbro 255 pump
Meth Kit with dual outside threaded M5 nozzles/DO check valves
FTP-Racing PnP'd S3 manifold
FTP-Racing PnP'd Evo 8 16g6 turbo
Maxfabb o2 housing
Needswings cutout DP
South Bend S4 Clutch
PTP check valve
FTP-Racing Catch Can
K&N drop in filter
Champion 570 spark plugs
JMB Coldside pipe w/Greddy type-s bov
SAFC2 & MSD tach adapter
FTP-Racing Grounding kit
FTP-Racing 26lb battery
FTP-Racing Ported Intake Mani/TB/Spacer
Meagan Coilovers
FTP-Racing Traction bars/chassis brace
FTP-Racing Solid Motor/Trans mounts
Flick 17x8 wheels wrapped in 235/40/17 Azenis
Polyurethane Endlinks
Blitz electronic boost controller
AEM wideband
FTP-Racing ECU Reset Kit
Aeoforce Pro Scan gauge
Autometer 30/30 boost gauge
FTP-Racing SS Weighted Shift Knob
AGP Big FMIC
McCord Power plate
Waiting to Install:
FTP-Racing Oil Restrictor
Crane 14 Cams
Fidanza Cam Gears
Definate Future Mods:
Drag Radials for the street
Possible Future mods:
62mm TB
B&G Reflash
Welfare Sways and Tension Bars
Rage LCA Bushings
Traction Controll
Dyno Graph:
Car is boosting 22-23psi on 91 pump + meth falling to 21@redline. I still need to tune it in a little more but my scan gauge just busted. The crane 14's and our oil restrictor will be going in as soon as the gauge is fixed and i'll be dyno tuning it. The goal is 400whp on pump + meth, and 430whp on a race gas tune. A 62mm TB is really the only other important bolt-on the car doesn't have so i may look into one if the cams/gears/oil restrictor don't get me to my goal.
I have been asked a few times now if i'd ever plan on offering this kit, but getting the s3 manifold's is pretty much out of the question to do it. If you can supply the turbo/manifold we can make anything happen for you. An evo 9 16g6 should show gains close to 20whp over the evo 8 i have. Also making it externally gated would probably net close to another 20whp on top of that. Either turbo can be upgraded to a 20g wheel(44lb) to make even more power. Maxing a setup like this out would be somewhere around 460-470whp on race gas with all the fixings. At that point the head is too much of a restriction and the turbo starts to run out of breath. However, that much power in a FWD car is more than enough to tickle your fancy. With a built motor, some squeeze can be added to put that beast into the 10's.
Anyways, i'm just adding this here incase anyone wants to know what our cars are like here at FTP-Racing.
Jason and i will be going for low 11's in december, and then next year 10's for his car. 9's are the ultimate goal for Jasons ride, but it is going to take alot of work to get there. Feel free to ask questions.
-Garrett
Garrett@FTP-Racing is offline
Old 11-07-2007, 01:07 AM   #2 (permalink)
beyondspexj's Avatar
Member Number: 30264
Trader Rating: (30)
i agree with ya, wish s3 manifolds were easier to get a hold of. i was almost thinking of grabing a agp log mani, exhaust flange for a t3/t4 and a evo exhaust flange 9 weld em together to create a custom plate ) and bolt the entire evo turbo to that. then of course that would require the use of the evo 02 housing and a custom downpipe.. a hell of a lot more work...
beyondspexj is offline
Page generated in 0.18201 seconds with 11 queries
