Old 03-07-2009, 09:10 PM   #1 (permalink)
ojcool's Avatar
Member Number: 19382
Trader Rating: (13)
Default Why do I update? Every time it's a disaster
F'ing SCT update, now my software does not recognize any PCM code.
I am trying to pass off my shifter as a Maddog shifter so I can make a quick buck.
ojcool is offline   Reply With Quote
Old 03-07-2009, 11:52 PM   #2 (permalink)
phubarr's Avatar
Member Number: 36947
Trader Rating: (56)
Mine's been doing that since day 1...
Not only do I have to uninstall, I have to delete ALL the files in the Advantage program folder and reinstall from a clean slate EVERY time. My roommate is a programmer and he said that the uninstall program only removes files the install program puts in. Apparently updating the program adds files, but the uninstall wont remove them. If you don't delete the whole folder, it still gives the same errors after a reinstall.
I had to figure this out on my own... hope it saves you some headache.
2005 Black Dodge SRT-4 ACR - SCT PRP (S2 base), ND Performance TCS, Mopar Stage 3 Coilovers, Falken RT-615's, AFE Stage 2 CAI, Ported 52mm TB, MaxxFab 3" DP (catless), Innovate LC-1 wideband, Aeroforce Scan Gauge, and a Hurst Shifter.
1989 Black Dodge Daytona Shelby Turbo II
1972 Plum Crazy/Black Plymouth Roadrunner
phubarr is offline   Reply With Quote
Old 03-08-2009, 11:01 AM   #3 (permalink)
SRT-What?'s Avatar
Member Number: 10224
happen to a bunch of us two weeks ago. Go on their dorum. Find a thread called " Lost access to all me previous tunes DCX" and fallow their directives.
Good luck
SRT-What? is offline   Reply With Quote
Old 03-08-2009, 12:08 PM   #4 (permalink)
Mana4real's Avatar
Member Number: 25021
Stew, you gotta contact MikeT at SCT... That's why I haven't updated in forever. I don't want to go through BS. I plan on updating once datalogging comes out... So maybe never.
-Matt- -SCT Tuned- By Yours Truely
Old 03-08-2009, 07:04 PM   #5 (permalink)
JANNETTYRACING's Avatar
Member Number: 10982
Simple fix, before updating, go in to advantage folder and delete racer.dbb folder, then update and it will replace it.
It is a known bug.
Ted.
JANNETTYRACING is offline   Reply With Quote
Old 03-09-2009, 12:04 PM   #6 (permalink)
Mana4real's Avatar
It's not a simple fix ted. He is one of the first prp owners. So he needs his dongle updated. Somehow SCT managed to screw up all the original dongle users.
Old 03-09-2009, 12:07 PM   #7 (permalink)
Sorry, sounded like the same Issue I have every time I update, I have to delete my racer.dbb folder or I lose access to my racer codes.
Ted.
Old 03-09-2009, 12:28 PM   #8 (permalink)
ojcool's Avatar
Trader Rating: (13)
I hope this doesn't mean what I think it might mean.
Old 03-09-2009, 12:35 PM   #9 (permalink)
ojcool's Avatar
Trader Rating: (13)
It is a known bug.
Ted.
I did try your fix while I am on hold here and no it did not work. It did replace the file b/c the original file was 1kb and the new one was 9kb. Thanks though.
Old 03-09-2009, 12:42 PM   #10 (permalink)
ojcool's Avatar
Trader Rating: (13)
Quote: Originally Posted by dodgez View Post
Because SCT is a piece of shit and so is the their SRT support. They need to stick with Mustangs......
Well, there are special circumstances here.
Old 03-09-2009, 04:43 PM   #11 (permalink)
Mana4real's Avatar
Me too... This is why I haven't updated... I am right in the middle of something right now.
Old 03-09-2009, 04:51 PM   #12 (permalink)
SRT-What?'s Avatar
Well just to let you guys know, everything works better then before on my computer.
By "before" I mean "before I had my access removed and restored".
I don't know if it was a trick from SCT to know who has access to everything or just an additional error from them...
Old 03-10-2009, 11:25 PM   #13 (permalink)
SkullingAxe's Avatar
Member Number: 39463
Trader Rating: (13)
Probably just an addition error. I updated mine a little while ago and ran in to the issue. Contacted MikeT@SCT and got everything back to the way it was before. I updated recently and it lost access to my pcm codes(again). I just reran the update from the actual SCT folder on my computer(not the link on the desktop, the actually updateadvantage.exe file) and it ran just fine.
2005 - Flame Red SRT-4
SkullingAxe is offline   Reply With Quote
Old 03-11-2009, 11:11 AM   #14 (permalink)
Mana4real's Avatar
I always update from the file in the folder... I have had to do that almost since I got it to avoid errors. The shortcut never works right.
Old 03-11-2009, 12:19 PM   #15 (permalink)
ojcool's Avatar
Trader Rating: (13)
Well, After alot of phone time I did get it fixed.
Page generated in 0.24848 seconds with 13 queries
