fyi, do you have the s3 fuel? or are you just using returnline?
Don't have the S3 fuel rail or a return line... I have the 3 bar map/tip, 675cc injectors (780cc@58psi), 255LPH high pressure pump, and a fuel pump re-wire. Those are my fuel mods... What's up?
I could be wrong, but I think you should use the S2 code and then work it from there. The S3 is more programmed for the the S3 fuel kit.
I have heard otherwise from someone actually doing it. I am going to try the S3 code first, then if I can't get it to run correctly, then I will revert to the stage 2
Is there a specific reason you decided to go with the S3 code? I'm curious because I've considered using it... Honestly, I hate the timing maps though; way too low IMO.
Anyway, I'd like your thoughts. Thanks!
Because there are a lot more cells that are more useable in the S3 code. It's also already setup for the WGA duty cycle table among other reasons. I think it's going to work out. It's all trial and error (hopefully not to much error )
Quote: Originally Posted by wannasupra
maybe do a return line. dunno, keep us informed, regardless.
I don't want to do a return line. But I will keep you guys posted. I sent the manifold out to be ported and coated today. Hopefully the install will be on the weekend of July 4th... Pending the manifold returning to me.
