Old 07-09-2009, 09:28 PM   #1 (permalink)
Member Number: 57992
Default which WGA for Mopar S3 turbo
Hey SCT guys,
Which WGA is best to use with SCT-tuned PCM controlled boost w/ a S3 turbo? I'm stock turbo + Mopar S2 WGA + PRP at the moment.....this combo gives me whatever I ask for via PRP, easily holding 18+ psi to redline with complete tunability. Bob at FnF has my S3 turbo at the moment....getting some port/polish/ceramic love....I have a mopar S3 WGA in hand. Just wondering if I should source a different WGA.
Opinions? Please only comment if you have experience w/ PRP & tuning PCM controlled boost w/ a S3 turbo. Thanks!
tcain02 is offline   Reply With Quote
Old 07-09-2009, 10:44 PM   #2 (permalink)
nemiro's Avatar
Member Number: 32732
Trader Rating: (166)
AGP S3 WGA is the best, by far. I hated the AGP WGA on the stock turbo, but it works really well on the S3.
Neil Emiro
2005 Dodge SRT-4
nemiro is online now   Reply With Quote
Old 07-10-2009, 08:14 AM   #3 (permalink)
SebringLX's Avatar
Member Number: 48080
Mopar S3 WGA works fine, but I haven't tuned any S3's with aftermarket WGAs, they've all had the "stock" S3 WGA.
I wish SCT would clean up the S3 code, still a lot of values that don't look right when you're editing a tune in Advantage.
One of a kind custom turbocharged 2004 Chrysler Sebring LX Sedan
.:CarDomain:.
13.5 @ 102mph
SebringLX is offline   Reply With Quote
Old 07-10-2009, 11:16 AM   #4 (permalink)
Mana4real's Avatar
Member Number: 25021
I have the Forced Performance stage 3 turbo and I run the stock S3 WGA... I have it at 25 psi right now, no spike, just a straight hold. Works fine. With a stronger WGA spring it may spool a little bit faster and it will keep the torque/power curve a little more even.
-Matt- -SCT Tuned- By Yours Truely
Old 07-10-2009, 11:18 AM   #5 (permalink)
srt4geezer's Avatar
Member Number: 910
Trader Rating: (13)
I'll vote AGP WGA. Go with normal spring weight on it.
11.9@117 so far.
Wiseman - Just cuz someone else has a fast car with the same parts as you, doesn't mean your car is fast.
Work harder, millions of people on welfare are depending on you.
srt4geezer is offline   Reply With Quote
Old 07-10-2009, 08:47 PM   #6 (permalink)
Thanks for the input guys. I'll probably start w/ the stock S3 WGA and go from there.
Nemiro/Geezer, any specific reason why the AGP? I realize it's pretty much mandatory for the 'stock' S3 PCM, but with PRP & the ability to modify the desired torque & WGA Duty Cycle tables, what is the advantage of the AGP WGA? Just trying to understand the benefits. Thanks for the help.
Old 07-10-2009, 11:26 PM   #7 (permalink)
srt4geezer's Avatar
Member Number: 910
Trader Rating: (13)
With the other variables not sure. Just try em & tell us how it works.
Old 07-11-2009, 10:26 AM   #8 (permalink)
nemiro's Avatar
AGP WGA allows quicker spool up, but it also allows you to hold more boost to redline. There are some PTB issues, as there are with any aftermarket WGA, but they are really not too bad on the S3.
Page generated in 0.15792 seconds with 13 queries
