Old 05-12-2008, 05:28 PM   #1 (permalink)
Member Number: 31650
Default weird timing
ok i have a friend that have a prp
she's running an almost stock stage 2 tune..just added around 2 degre from 3500 and above
when i look at here timing curve the timing is way low from 3000 to 4500 and after that it come back up...i doesn't incease proportionally to rpm like mind does (and boost)
on here setup the tip is not connected to the cold pipe and embiant temp sensor is hanging in the engine bay.
i.m juste wondering if one of those 2 would be responsable for that weird timing ??
we check for knock with the aeroforce at first and no knock
Not stock anymore
Old 05-12-2008, 05:35 PM   #2 (permalink)
$PK$'s Avatar
Member Number: 47676
Considering that charge temp plays a major role in dtermining your timing, Id say that thered line and the IAT sensor not being hooked up is messing with the timing.
401whp 419wtq tuned by Jannetty Racing Enterprise
$PK$ is offline   Reply With Quote
Old 05-12-2008, 06:16 PM   #3 (permalink)
sp33d's Avatar
Member Number: 14683
Trader Rating: (34)
hmm... kinda having the same issue 6200 and up... should be about 20* 6k and up... and it drops to abe 11* to 7k.
no knock also...
is the block stock? any headwork?
450+ WHP BWs256 500whp or BUST
sp33d is offline   Reply With Quote
Old 05-12-2008, 07:40 PM   #4 (permalink)
stock block if i remember correctly...
Old 05-13-2008, 08:34 AM   #5 (permalink)
sp33d's Avatar
Trader Rating: (34)
i wonder if any one can chime in... what other factors does the pcm take in to adjust timing other then knock?
the temp sensor should not make a difference , well did not for me anyway... i had 3" CAI with the temp sensor in and compared to the 4" SRI with the sensor out the timing is droping at the same place on the dyno sheet (6200) if that was the case.. should be across the board not just one section of the rpm band. tell me if i am not correct on this please.
now i have a SRI so.. the temp sensor should not matter for me too much.. have it right where the filter is so... yea.
CAI or SRI?
if you have a cai... would not hurt to put the sensor in.
also... is the car on stock boost noids? / pcm controlled boost?(solinoids 1,2,3?)<spelling?
how much psi?
Old 05-13-2008, 09:18 AM   #6 (permalink)
$PK$'s Avatar
colder spark plugs?
Old 05-13-2008, 09:41 AM   #7 (permalink)
Member Number: 18054
I think PK was talking about the air temp sensor on the charge pipe by the throttle body.
CAI or SRI?
how much psi?
STOCK: 233whp/248wtq (dynojet)
13.88 @ 101.1mph
STAGE 3 + bolt-ons, on 91 octane:
344whp/366wtq (dynojet)
11.9 @ 116mph (HOM with slicks)
wonderboy is offline   Reply With Quote
Old 05-13-2008, 09:45 AM   #8 (permalink)
$PK$'s Avatar
yessir
Old 05-13-2008, 11:27 AM   #9 (permalink)
wannasupra's Avatar
Member Number: 32741
Trader Rating: (10)
stage 2 has very conservative timing iirc. that's why it's a good base for a big turbo
"Scoff not at my vile remarks horny fiend"
Old 05-13-2008, 02:52 PM   #10 (permalink)
sp33d's Avatar
Trader Rating: (34)
according to moreause, he is talking about the ambiant temp sensor... the one for the intake. atleast that is how my scan guage reads them (ambient= intake pipe, intake is cold pipe)
moreause, can you please clarify
Old 05-14-2008, 10:26 AM   #11 (permalink)
SRT-What?'s Avatar
Member Number: 10224
The air temp sensor is in the 'cold air hole' in the fender.
the TIP sensor is NOT pluged into the coldpipe. We should have a nipple welded soon.
The intake manifold is port matched to the head.
The turbo is only boosting 18 psi. The tuner (a reputable shop near montreal) didn't wanted to raise the boost. I had to leave when the car was still making 273whp. When I phone to ask how he was doing, he told me he wasn't able to make more than 350whp-350ft-lbs. I ask him how much boost they were running and he told me he didn't want to raise over 18 psi. The turbo is quit large (secret receipt from another reputable shop), something like a 60trim and I think we could make another 30 whp at 20 psi.
Also, I suspect the wastegate dumping into the downpipe to be stealing some power...
We'll start by correcting the TIP and Air temp sensor first...
Any feed back would be greatly appreciated
SRT-What? is offline   Reply With Quote
Old 05-15-2008, 12:57 PM   #12 (permalink)
wannasupra's Avatar
Trader Rating: (10)
18 psi and you're only making 273? i made 330 at 19 psi, and i didn't have any headwork at all.
Old 05-15-2008, 01:06 PM   #13 (permalink)
wannasupra's Avatar
Trader Rating: (10)
and that was with a map clamp
Old 05-15-2008, 02:03 PM   #14 (permalink)
SRT-What?'s Avatar
no, you read wrong.
I left the shop when the car was making 270 whp at 4000 rpm. He was making pull at low rpm to see how the timing, afr were. The car is making 350 whp @ 18 psi. Which is still not enought !
Old 05-20-2008, 10:54 AM   #15 (permalink)
Member Number: 34188
Normal de baisser le timing au peak torque et remonter apres
P.S avec le meme turbo Nick a sortie 431Whp\443Wtq @ 22 psi au 94oct (tune safe) et 487Whp/508Wtq @ 27psi au C-16 (tune safe)
il est toujours sur le moteur stock
04 Twin Turbo SRT-4 11.797@123.535MPH
Inspired By Darrell Cox,Built & SCT Tuned By C&DAutosport
1fastVNT is offline   Reply With Quote
Page generated in 0.32064 seconds with 11 queries
