Old 03-24-2008, 03:24 PM   #1 (permalink)
TypeRvtec's Avatar
Member Number: 51963
Default Turboback exhaust. Should I reflash??
I just recieved and flashed my Xcal 2 weeks ago. It came from Pwerks. I told them I was bone stock with just a 2.5" cold air intake. And they sent me my unit with that specific tune. But now I am picking up a turboback exhaust tomorow. 3" maxfab dp, with the 2.5" dp back mopar/borla. How much tune is there? Being it's a can tune, can I get away without sending my unit back to pwerks and still be safe??
TypeRvtec is offline   Reply With Quote
Old 03-24-2008, 06:33 PM   #2 (permalink)
2Spools's Avatar
Member Number: 18960
Trader Rating: (17)
Do you have a wideband? More then likely that generic tune is way rich so the exhaust will help lean it out. Without getting on a dyno for a tune your going to be off on power anyways.At least your heading in the right direction.
2Spools is offline   Reply With Quote
Old 03-26-2008, 05:58 AM   #3 (permalink)
rrmike1's Avatar
Member Number: 55729
It's possible an update might benefit you. I too bought the xcal from them and they asked me to send it back when I put on a pnp'd turbo/mani. and 3" O2 for an update. How much good it will actuallly do since it's a canned tune I don't know yet. I'm not expecting to get my socks knocked off, but I definitely felt a difference in the butt dyno before flashing it back to stock.
Stage 2 w/o toys, FBM pnp'd turbo/mani., Rage 55mm T/B, AGP WGA, AGP CAI, MPx 3" O2, Maxxfab 3" DP no-cat, Mopar Exhaust, AEM UEGO, SprayItRacing BOV, Crane 8.5mm wires, Champion RE10pmc5's, 180 thermo, RFR check valve, Prothane race MM inserts, Autometer 30/30, SCT Tuner, Tein H-techs, Proparts dual-gauge pillar, Fuel pump re-wire.
rrmike1 is offline   Reply With Quote
Old 03-26-2008, 11:41 AM   #4 (permalink)
Member Number: 62727
Well, if you were running PCM controlled boost I would say yes, but with a boost controller, if you don't notice you boost pick up a pound or so with the new exhaust I would say there likely isn't going to be much power there to pick up. You tune is likely plenty rich as it is.
GT3076R, return line, stage II injectors, 4" short Ram, 3" Turbo back, STS, SCT Flash PCM managment.
----This is Ojcool, my account was put on a no access list for defending myself and other SCT section Members in OT----
There is such a fine line between stupid and clever. SPINAL TAP
Thermodynamics is offline   Reply With Quote
Page generated in 0.17105 seconds with 11 queries
