TIP Sensor, how do you remove it, and do you plug it into the Throttle body vac/boost
TIP Sensor, how do you remove it, and do you plug it into the Throttle body vac/boost?
Stock one plugged in (wires), but not hooked to anything besides that.
Installed SCT tonight, having issues... How do I put my 3 bar in there, and do I run the nipple to the vac/boost line on the Throttle Body?
Thanks for the help
Sponsored By: ClutchMasters, SnowPerformance, MadDog, 475hp, 468ftlb, 24psi on SAFC/Profec.
Now on the SCT - Waiting to Dyno with RaceGas + 25psi http://myspace.com/cybr
Thanks for the help
Well, if you have a 3bar you cannot just flash any tune into the PCM, the 3bar should be installed like stock. The flash should be a Stage II or III flash or the PCM will not understand the scalers. Use a stage II flash. and the car should make about 16psi. Get that working and I can send you a more agressive flash.
just don't hook the red line on the tb instead of the cold pipe..i did that when installing the sensor ...and the car was having a hard time just running
red line, white line, mine are all gone. the line from the tip sensor goes to the top (closest to plug) vac nipple on the red solenoid (#1). then the middle line on solenoid pack 1 goes to where? i have it tee'd into the throttle body, where's it supposed to go?
"Scoff not at my vile remarks horny fiend"
Quote: Originally Posted by unnecessary
Son Of A Bitch!@#!#@@#! You made me hit my Knee on the desk!
goes to the cold side pipe? o shit. i don't think i have a port on my coldside pipe for that line. sonofabitch. well, i guess i'll be re-doing my vac lines today. f@ck
If you're going AGP SCT, and have your own boost controller, you DO NOT NEED your 'noids hooked up at all. You need the TIP hooked to the plug, but not connected to the vacuum line, etc.
Well, that spells disaster right there. At a minimum, you really need your TIP sensor hooked up, per the original setup. The TIP does a bit more in the software than most people realize. After a solid week of testing all kinds of setups on SRTs, we found that it needed to be hooked up.
