Old 04-09-2009, 09:32 AM   #1 (permalink)
04blusrt_4's Avatar
Member Number: 60369
Default THings for +6500 rev
Just wondering if I should rescale the S2 code for an rpm column say around 6800 so that I can rev to 6500 without any fall off in timing / fueling. I am getting a D55, which really should have no issues making power up around 6500, my current S3 turbo falls off right around 6000 now.
Advice for tuning a better power curve above 6k?
*NE 400 Club*
Old 04-09-2009, 05:58 PM   #2 (permalink)
SRT-What?'s Avatar
Member Number: 10224
I started to look at this two days ago. Rescaling the fuel et timing tables is pretty straight foward and you can guestimate the values you want to run if the RPM columns are changing.
What scares me more is the VE table. It wont be easy to fill in the table with the new columns and I have nothing else than an aeroforce to help me out (useless?)
This is how I planned my WOT Fuel to be rescaled.
Blue is S2, red is 7k. Notice that I shifted the resolution towards the upper section. I don't go WOT often below 2000 rpm even though I run about the same AFR throughout the rpm band.
And the result:
Three columns in the turbo spooling RPMs compared to two for the S2. And the 7k redline.
SRT-What? is offline   Reply With Quote
Page generated in 0.12822 seconds with 13 queries
