Old 07-05-2008, 01:04 PM   #1 (permalink)
Member Number: 25021
Default Stage 3 code on an 05
Ok, so I put the stage 3 code into my 05... Found out right away that the stage 3 code that is made is for an 04 because my battery light came on right away. I don't have the temp sensor in 05... Anyone know how to get rid of the code and the battery light? I looked into the program and I couldn't find it.
-Matt- -Drastic-
05 SRT-4 Stage 3 47lb FP Green
Mana4real is online now   Reply With Quote
Old 07-05-2008, 01:08 PM   #2 (permalink)
DDogsrt461BLK 3.0's Avatar
Member Number: 32500
Trader Rating: (17)
Contact Powertowin\SP, because I think they sell a wiring kit, that allows you to use a 04 pcm in a 05 car with no cell. I'm not 100% sure on this, because I have a 04, but it's worth a shot.
Stg3 toys, ported head & intake, NX 4nozzle, progresser, wide ban, egt, fuel pressure, injen, samco, Mpx3", Maxxfab02,Greddy CC, Boomba's, AIS intercooler, STS, billet SS, .020 8-1 JE's, Eagle 4340 H beam rods, UDP, you name it I've done it Mopar Clutch
Don't be messing with my FJO!!!!
2 180+ Lph pumps feeding the bitch!!!!
DDogsrt461BLK 3.0 is offline   Reply With Quote
Old 07-05-2008, 01:13 PM   #3 (permalink)
HCCAFan's Avatar
Member Number: 35768
Trader Rating: (18)
Mana the voltage is different in 2004s and 2005s as well so you may have more to change than the code. With a 2004 flash my car runs 12.9-13.2 volts. With a 2005 flash it runs 13.5-14 volts.
HCCAFan is offline   Reply With Quote
Old 07-05-2008, 01:25 PM   #4 (permalink)
Trader Rating: (17)
Smile
No offense to you, but what's the temp difference between the 2 test? I only ask, because in the summer is will run about 1 volt lower then in the wintertime. Why? because it takes more energy to make electrons move in the colder temps. Trust me. I have a meth lab in my basement, so I know what I'm talking about.
Old 07-05-2008, 01:36 PM   #5 (permalink)
HCCAFan's Avatar
Trader Rating: (18)
How about I go outside and flash the car with a 2004 tune and video the voltage and then flash it with a 2005 tune and show you the voltage?
Old 07-05-2008, 01:47 PM   #6 (permalink)
Trader Rating: (17)
it's like that?
Old 07-05-2008, 02:11 PM   #7 (permalink)
HCCAFan's Avatar
Trader Rating: (18)
it's like that?
Nah, I just get mad when people act like I don't know what I am talking about. Hell maybe it's just my car. My car seems to be the exception to every rule. But I promise you, on my car, a 2004 flash runs lower voltage. Nemiro told me this is normal too.
Old 07-05-2008, 02:29 PM   #8 (permalink)
cybr's Avatar
Member Number: 31841
Trader Rating: (34)
but dude, he has a meth lab... he knows everything.
Sponsored By: ClutchMasters, SnowPerformance, MadDog, 475hp, 468ftlb, 24psi on SAFC/Profec.
Now on the SCT - Waiting to Dyno with RaceGas + 25psi
http://myspace.com/cybr
cybr is offline   Reply With Quote
Old 07-05-2008, 02:33 PM   #9 (permalink)
nightmare_rebuilt's Avatar
Member Number: 42066
Trader Rating: (41)
i thought n2mb had made something for this.
Parting out
nightmare_rebuilt is offline   Reply With Quote
Old 07-05-2008, 03:00 PM   #10 (permalink)
I am going to go back to the stage 2 code and see what happens.
Old 07-05-2008, 03:30 PM   #11 (permalink)
HCCAFan's Avatar
Trader Rating: (18)
Yeah...I don't really know what that means. I know what a meth lab is, but not what it has to do with batteries and voltage.
Old 07-05-2008, 03:55 PM   #12 (permalink)
Stage 2 code is working better for now.
Old 07-05-2008, 04:27 PM   #13 (permalink)
Nick Chestnut's Avatar
Member Number: 16791
Good to know!
- Nick Chestnut
* 2004 Dodge SRT-4, GT3076R, SCT Tune, 434 WHP & 491 WTQ!
"Don't argue with an idiot. They bring you down to their level and beat you with experience." - Unknown
Nick Chestnut is offline   Reply With Quote
Old 07-07-2008, 12:47 AM   #14 (permalink)
Quote: Originally Posted by Nick Chestnut View Post
Good to know!
Ya, the stage 2 code seems to work great so far. I have a lot of tuning to do. I added a lot of fuel when I put the stage 2 in to make sure that it was safe. So far it pulled really hard at about 22 psi and afr's were in the high tens, then when it went over about 4k it went really rich and slowed down a lot. But man I love the new turbo!! Just gotta get the fueling fine tuned.
Just to check for knock, I logged it tonight when I got home and there was zero knock. I was gone pretty much all weekend so I didn't get much chance to do any tuning before I left. I pretty much got a base tune in that worked and then took off. Also the car has more get up and go in vacuum. My mileage was also really f'ing good!! I think I just fell in love with my new setup
Old 07-07-2008, 07:51 AM   #15 (permalink)
Member Number: 31650
the voltage is probably due to the sensor
since 05 don't have one the always do full charge...but 04 can lower voltage to compensate for temp
for using stage 3 tune i think nemiro said that using a toys tune (like stage 3) on a non toys pcm would result in having toys setting switched on at startup and would go off when detecting knock!!
for fuel issue i currently use the stage 2 table to
i first change the power enrichement table to command 11.8 all over the table
that was good for a while and then one days the overtemp exhaust protection went in (i saw 9.7 afr) so i zeroed does value to
and the afr is more steady
Not stock anymore
