Old 05-18-2009, 01:55 AM   #1 (permalink)
csmsach's Avatar
Member Number: 33253
Default Shift Light?
Was looking through all the pcm codes in advantage and found a few that have Shift Light parameters. It is based on map and rpm. Anyone seen this working before? Maybe on the initial srt prototypes?
csmsach is offline   Reply With Quote
Old 05-18-2009, 12:20 PM   #2 (permalink)
nemiro's Avatar
Member Number: 32732
Trader Rating: (165)
Have not ever tried it, but you will have to add the shift light LED to the cluster to verify. There was something similar in the 80's turbo Dodges. You could add the bulb to the cluster, and change the programming to make it work.
Neil Emiro
2005 Dodge SRT-4
Page generated in 0.14023 seconds with 13 queries
