Thanks Sour Kraut for fixing the Gear Dependent Boost page!
correct me if i'm wrong in the power enrichement you said that the Y axis is in bar... if i'm correct this axis is unit less it's a ratio (like the name says)
I just figured out a really easy way to figure out what cell is what on the boost by gear table. I played with my datalogger a lot tonight and found out a bunch of useful tools. I can figure it out pretty damn easy and then post up my results. It will be this weekend though before I have more time to play.
Just FYI, I played with this last night and apparently it is working!
I believe I have confirmed what Dave at SCT told me though I still need to do more testing to be 100% sure.
Cell 10 = First Gear
Cell 8 = Second Gear
Cell 7 = Third Gear
Cell 6 = Fourth Gear
Cell 5 = Fifth Gear
I'm going to do some more playing around tonight to confirm those results!
Auto enginuity... Going to use the standard part of it, not expanded and run the MPH, RPM, Barometeric pressure, and record. This should give you a pretty accurate idea of where everything is. Look for huge changes in barometric pressure at different speeds/rpm when you look at the excel file and it should be pretty easy to locate the cells
That's pretty much what I was going to do in the next few days if we can ever get this damn sr20det swap done!! 99% of the time I use the general logger. I hate the extended datalogging but it's come in handy a few times.
The only thing you can really use the extended for is knock retard. Plus it's a lot slower then the standard.
But it should read "Your F/A ratio can be determined by dividing 1 by your A/F ." assuming the actual formula is right (i'm assuming because f/a divided by 1 is still f/a.
Minor correction. In the power enrichment above stoich FA Ratio wiki and in the stoich FA ratio wiki, you have stated:
Keep up the good work guys!
-Bob
you could really confuse people by telling them, "Your F/A ratio can be determined by taking the inverse of your A/F", but the software is confusing enough.
That's just mean. Anyone that isn't a math person would just sit there and
