Old 07-02-2008, 04:13 PM   #31 (permalink)
04blusrt_4's Avatar
Member Number: 60369
Quote: Originally Posted by sour kraut View Post
Nope. The original thought was that it was tip voltage, but it's not. The throttle is what you use to request torque, the more throttle you give it, the more torque you want. Pushing the gas pedal all the way to the floor will only get you approx. 2.8 volts on the TPS signal, that's why there are no rows after that voltage. You can't ask for more torque than you are asking for at WOT. The lower voltage rows are "part throttle" rows. Less throttle means you want less torque. I guess this should of been in the explination on the wiki but it can always be added.
looking through the codes, wot is at 2.331v on the tps.
I was confusing MAP vs TIP voltage, I stand corrected
*NE 400 Club*
Old 07-03-2008, 12:27 AM   #32 (permalink)
Member Number: 31650
The NGC is a very generic controller. Chrysler is using it on allot of cars that are both automatic and manual. In the cars with manuals there is no way to know if it is in gear or in nuetral so it ignores the "in gear" limiter and always works from the "in nuetral" limit. This is why gear based torque reduction doesn't work. The car doesn't know what gear it is in or if it is even in a gear.
i will have to try it to confirm
but from what i know yes you can adjust max torque my gear it change a bit from code to code
the pcm know the gear comparing rpm and speed
Not stock anymore
Old 07-03-2008, 12:30 AM   #33 (permalink)
just a point about the tps voltage .... the tps voltage in the table and the tps voltage you see on your aeroforce is not the real tps voltage
it has the same span so around 2.8 volt but does not show the 0.7V offset
the real voltage is more like when you look at the % value is around 15 to 75 % of 5V
Old 07-03-2008, 10:38 AM   #34 (permalink)
Nick Chestnut's Avatar
Member Number: 16791
That was my understanding as well...
Note: I am no longer offer tuning services. Please contact another vendor for tuning. I'm no longer going to compete with people who half ass things, make empty promises, and insist on flat out doing things the wrong way. I apologize for any inconvenience this may cause...
* Nick Chestnut *
* 2004 SRT-4, GT3076R @ 498WHP/502 WTQ *
Nick Chestnut is offline   Reply With Quote
Old 07-07-2008, 10:47 AM   #35 (permalink)
Technical Tuning & EFI/EMS Electronics moderator
sour kraut's Avatar
Member Number: 19796
which processor code are you guys using then? I've been working with the 05029832AE. It shows a table for 0 to 10 gear, but has had no affact on my power levels. Speed based has been the only thing that has worked for me so far. If it's working in one of the other codes, let's get that documented on the wiki!!!
sour kraut is offline   Reply With Quote
Old 07-07-2008, 12:48 PM   #36 (permalink)
I haven't actually confirmed it works yet but Dave with SCT said he has successfully used it.
I'm using the 04510850AA processor code. I'll try to see if I can confirm functionality tonight...
Old 07-08-2008, 10:59 AM   #37 (permalink)
sour kraut's Avatar
Any word on this? If you didn't get a chance, I'll probably try it again in a different code tonight.
Old 07-08-2008, 11:20 AM   #38 (permalink)
Well, I tested it last night and it does NOT appear to work. I'm going to contact Dave and see if he can shed some light. For the moment though it's no dice!
Also, how were you able to get the speed based boost to work? That table only has one row from the calibrations I've seen...
Old 07-08-2008, 12:23 PM   #39 (permalink)
Mana4real's Avatar
Member Number: 25021
045108500AA
Gear dependent boost control....
Right now I have cell:
0 300
1 500
2 600
3 600
4 600
5 600
6 600
7 600
8 600
9 600
10 600
What this does is gives me 10 PSI in first gear till about 5K then it shoots up to 15...
Second gear was at about 22 or 23 PSI with my E1... I need to play with it more and get it down.
I have a decent tune now, so this was next on my list to play with... I should be messing with it within the next week.
-Matt- -SCT Tuned- By Yours Truely
Old 07-08-2008, 12:58 PM   #40 (permalink)
SRT-What?'s Avatar
Member Number: 10224
that means that you are not running the 3 bar map and tip sensor ?
and that you have to change your redline to 6.5 ?
I'm thinking about switching to the S0 processor code in order to have the speed dependan boost control, but I'm to lazy to switch all the other features of the S2 code...
SRT-What? is offline   Reply With Quote
Old 07-08-2008, 01:06 PM   #41 (permalink)
sour kraut's Avatar
straight from the wiki;
Description:
This funtion is a little backwards. You cannot limit boost by gears because the car is a manual but you can limit the boost by MPH. There are only 2
processor codes that have the 5 value tables for this. These are 05029832AE and 04510848AA. All the other codes only have a single value. To be
able to use this funtion you need to start with one of these 2 codes.
As far as copying everything over to a stock tune from a stage 2 tune, you can check mark all the needed areas(turbocharger, speed density, fuel, etc.) and save those out of the stage 2 file and then load them right into the stock tune. You do have to check that the numbers still make sense because sometimes they get scrambled.
Old 07-08-2008, 01:19 PM   #42 (permalink)
Mana4real's Avatar
Yes, I am running the stage 2 code. I have the 3 bar sensors and redline is set at 6500 already with stage 2. I will get it somewhat figured out soon. I don't want to switch everything over. I should be fine running the stage 2 code... I don't see any downfall to it. When smog time comes around I am going to put it all back to stock anyways. Stock tune, injectors, sensors... No big deal. It's easy.
Old 07-08-2008, 02:22 PM   #43 (permalink)
Member Number: 319
Isn't it possible to determine which gear you are in by correlating RPM and MPH?
Old 07-08-2008, 02:32 PM   #44 (permalink)
Description:
Wow, go figure! I need to pay more attention!
Mana, so you have had luck with the gear specific boost? Last night I played with all the values and could not change boost at all. No gear showed any signs of boost reduction or increase. You should definitely play around with it on your car and see what you can come up with. This is a feature I definitely would like to have.
Old 07-08-2008, 02:33 PM   #45 (permalink)
Yes. That's how the AVC-R works...
Page generated in 0.21254 seconds with 14 queries
