Old 05-06-2008, 08:19 PM   #46 (permalink)
NoisufnoC's Avatar
Member Number: 136
Quote: Originally Posted by duster360 View Post
Its called an S0 ecu and ECU controlled boost. Engineers ususally use 85-86 octane for calibration.
quoted for troof.
that PCM will adjust itself for the lower octane. you wont make as much power, but it wont let you blow up either.
GTFO with your Stage 0 Nonsense!!
omgz!! i haz mods!!
NoisufnoC is online now   Reply With Quote
Old 05-08-2008, 11:28 PM   #47 (permalink)
Member Number: 60912
Anyone mix nitromethane with E85??
I know it's like nitrous to engines on alcohol, and it's commonplace in the r/c world.
SinCitySRT is offline   Reply With Quote
Old 05-09-2008, 12:49 PM   #48 (permalink)
ojcool's Avatar
Member Number: 19382
Trader Rating: (12)
Quote: Originally Posted by SpeedEuphoria View Post
the main hurdle would be ONLY using E85, not switching back and forth.
The A/F doesnt matter, its an O2 sensor it reads Oxygen the PCM wants 14.7=1 Lambda, if you change to E85 and leave the computer thinking its gasoline it will still try to get 14.7 or Lambda 1(which will really be A/f of 9.2 or whatever). A/F is just a number like HP, to get it you use a multiplier and the real data which is Lambda or Torque, its just that people use different multi's to get different A/F's and normally dont with HP.
A narrowband 02 sensor cannot read this range, sometimes when a a/f ratio is WAY outside the range of a sensor it has the nasty tendency to peg Pig RICH even when it's actually a lean condition. I don't need to tell you what this would do to your a/f ratio.
[W]e made a great mistake in the beginning of our struggle, and I fear, in spite of all we can do, it will prove to be a fatal mistake. We appointed all our worst generals to command our armies, and all our best generals to edit the newspapers Robert E Lee
ojcool is online now   Reply With Quote
Old 05-09-2008, 03:22 PM   #49 (permalink)
duster360's Avatar
Member Number: 45182
all O2 sensors, even wide bands read Lambda not A/F. Widebands just do it differently and then the A/F is just a conversion you tell a guage to make.
E10, E85, E20, M85, Petrol, Methanol, diesel, keroseen, jet fuel, Propane, Nitromethane, Natural Gas, Wood, what ever, will ALL be read by any O2 sensor as lambda = 1.0 when the mix is stoich. For a narrow band O2 it will pump out .45 volts. Now everyone listen carefully,, this is the tricky part: If you have a wideband with a Gauge SET BY THE USER to OUTPUT LAMBDA = 1.0 = A/F = 14.7, then ALL THE FUELS, WHEN LAMBDA = 1.0, WILL READ AS 14.7 ON THE GUAGE REGARDLESS of WHAT THE TRUE A/F IS!!!
If you change the guage so that Lambda = 1.0 is = to an A/F of, lets say some thing crazy, 45:1, then for ALL fuels when the mix is at stoich will read at 45:1. Now is the A/F really 45:1?? Of course not.
A guage's interpretation of Lambda is all relative to the USER and NOT a function of the O2 sensor.
Old 05-09-2008, 09:55 PM   #50 (permalink)
Member Number: 32732
Trader Rating: (129)
Bingo!
Neil Emiro
2005 Dodge SRT-4
Old 05-14-2008, 12:11 AM   #51 (permalink)
dj4monie's Avatar
Member Number: 977
Now would the flex-fuel B series vans for example have the feedback sensor you mentioned 360?
Now S3R Powered!
dj4monie is offline   Reply With Quote
Old 05-14-2008, 08:19 AM   #52 (permalink)
duster360's Avatar
Quote: Originally Posted by dj4monie View Post
Now would the flex-fuel B series vans for example have the feedback sensor you mentioned [Duster]360?
I don't think so. I'm not aware of any flex fuel engines availible in B vans. What model year and engine are you referring to?
I was thinking specifically of 3.3l minivans, which have all been flex-fuel since 1998 (I think the years right).
Old 05-20-2008, 03:56 AM   #53 (permalink)
dj4monie's Avatar
Member Number: 977
I remember the last of the B-series full size vans before they were phased out, were Flex-Fuel if you ordered it.
I see the '08 Avenger is available as a Flex-Fuel model...
Do the mini-vans have that sensor and could it be integrated into the Neon's harness?
I am mostly going to use E85 as a replacement for high octane unleaded fuels which are around $7 a gallon.
Found this interesting link -
Kick the oil habit and make your own ethanol | Science | Reuters
$10k is bit steep but takes the "Neck" out of making your own fuel....
EFuel100, Earth's First Home Ethanol System, a Product of E-Fuel Corporation Now Taking $3K downpayments
Old 05-20-2008, 08:50 AM   #54 (permalink)
duster360's Avatar
Even though B vans used a JTEC engine module, I can't engine why Chrylser would use a different functioning "ethanol" sensor. I'm sure every model had a different part # sensor to account for a different fuel line, mounting bracket, and electrical connections, but the core sensor is probably the same. I'd still find one from a NGC3 vehical just to keep the variability down.
I deffinately hit up Neil E on this. He's working on it anyway.
Old 05-20-2008, 10:12 AM   #55 (permalink)
Yes, I am working on it, and yes, the '08 Avenger is a NGC car, with an ethanol sensor. I am months away from anything conclusive, so don't start banging on my door for a tune, it's just not there yet, and I won't release anything until it has been tested to my satisfaction.
Old 05-20-2008, 10:58 AM   #56 (permalink)
NoisufnoC's Avatar
Member Number: 136
Very cool stuff. I'll keep my eyes on this thread.
Old 05-22-2008, 02:12 AM   #57 (permalink)
Member Number: 30138
Is having aem standalone any different? Or can i just get tuned on e85 and be fine.
E1 with Ext WG
AEM EMS
+ Bolt-ons = Sick Lil TD04
JRoye is offline   Reply With Quote
Old 05-22-2008, 10:24 AM   #58 (permalink)
Member Number: 64119
alright. sign me up for e85.
if nemiro tells me what to order, ill buy some injectors and will change my car up to e85 in a month or so.
750cc*30% = 1005ccinj.
think 950s + m13 nozzle of meth will do the trick?
im tired of paying 4.20 for shitty 91oct.
i FIRSTLY need to research where we have e85 pumps at around here.
Santiago. is offline   Reply With Quote
Old 05-23-2008, 09:26 AM   #59 (permalink)
NoisufnoC's Avatar
Member Number: 136
i'm almost there too. I have 2 - 3 E85 stations near my house
keep in mind though, Assuming that $4.20 is your premium price, then $4.00 is regular and E85 is usually $.10 less... so $3.90 + 30% = $5.07/gal
Old 05-23-2008, 09:51 AM   #60 (permalink)
it just hit 4.30 for 91 yesterday.
are you saying +30% due to the extra fuel needed?
does it actually consume 30% more during idle/close loop conditions?
i could see while WOT...but 30% MORE consumption at idle/Closed loop is pretty crazy.
still cheaper than the 5.85/gal for race gas...
i just want more octane.
