Old 04-30-2008, 05:08 AM   #1 (permalink)
ASRdaVe's Avatar
Member Number: 36852
Question sct for 03?
any chance are they working on a flash device for the 03's??? question has prolly been asked however i might be too blind to see if there was a thread for that fun stuff thanks in advance for whoever answers my question
2003 srt-4 flame red
kinetic wastegate
hallman boost control
agp up pipe w/ hks ssqbov
05 trans
acr rims
MPx 3inch turboback
megan coilovers
sbc rear control arms
04 580cc injectors
1995 talon tsi awd
ASRdaVe is offline   Reply With Quote
Old 04-30-2008, 08:22 AM   #2 (permalink)
Member Number: 31650
yep would like to see a confirmation on that one
i think sct doesn't really support it, but can work
i think for now the best way is still to change the pcm to an 04 and then reflash it
i know some 03 sct guys a over here somewere just don't know the exact recipe....they will probably show up
Not stock anymore
Old 04-30-2008, 08:29 AM   #3 (permalink)
rasp's Avatar
Member Number: 56076
My staged '03 ECU works with SCT flashes perfectly fine.
I believe it's stock '03 ECUs that can't.
Old 04-30-2008, 09:21 AM   #4 (permalink)
yep only stock 03 as the issue...they are physically different
Old 04-30-2008, 12:10 PM   #5 (permalink)
Member Number: 2930
Trader Rating: (10)
Who is going to reflash the 04 pcm for you?
bspstang is offline   Reply With Quote
Old 04-30-2008, 02:14 PM   #6 (permalink)
oups forgot about that one, dealer can do it, but for some reason some don't know and don't want to know how to
Old 05-01-2008, 12:59 PM   #7 (permalink)
ASRdaVe's Avatar
Unhappy 03 sct flash
so back to that question, the answer is flash to stage 1? or what? i am sorta confused ... my interperation of what you guys are saying is that the 03's just wont work with sct unless flashed or an 04 pcm, so i will still have to pay 300-400 dollars for a flash and then another 500 just to get the use of the sct flash? ... that sucks
Old 05-01-2008, 01:24 PM   #8 (permalink)
Member Number: 2930
Trader Rating: (10)
PM SCT let them know you would buy if they had it. The only way to get them to support it is if they see a market for it.
Old 05-01-2008, 01:46 PM   #9 (permalink)
ASRdaVe's Avatar
Thumbs up pm sct
i hear that ... doing that after this post
Old 05-01-2008, 01:50 PM   #10 (permalink)
the probleme is that the stock 03 pcm is not built in the same way as the later pcm and stage...
so to buy pass this, you can get a 04 stock pcm...but you have to get it set your vin....and for soem reason flight system won't do it on a stock one (probably legal stuff) and some dealer will say that it can't be done....but it's exactly the same as a stage
a flash at the dealer should be less than 75$ in my mind...and around 0.5h to change the pcm
for a custom flash plus xcal2 is around 650$ if a remember correctly, or buy a ptp package for 1000$
Old 05-01-2008, 03:54 PM   #11 (permalink)
uberingram's Avatar
Member Number: 447
SCT works on my stock 03 PCM.
Chris ~ Janky '03
uberingram is offline   Reply With Quote
Old 05-01-2008, 04:38 PM   #12 (permalink)
ASRdaVe's Avatar
Default sct flash
thank you for the advice on the 04 pcm thing that might just be th route i take ... kudos to the people that give me advice thank you all very much
Page generated in 0.18776 seconds with 11 queries
