Old 09-26-2009, 12:03 AM   #1 (permalink)
Member Number: 31650
Default returnless fuel
i installed a rising rate on a friend's car
and i have issue tuning back the fuel
and is it me or the tableof stage 2 returnless fuel is not correct compare to stage 0
the 1 value isn't centered with the 0 pressure
i tried rescaling the injector at 58 psi (was ok before rising rate)
and put the lower value of that table to 1 like in the table
but i end up with afr in the 10 instead of the commanded 12 ..weird
hum i think i will hav eto confirm that it's really a 1:1
Not stock anymore
Old 09-26-2009, 11:17 AM   #2 (permalink)
nemiro's Avatar
Member Number: 32732
Trader Rating: (165)
Well, first off, that table is really jacked up in Advantage. Second, the values are not even close to correct in the left column. Third, you have the 3 Bar MAP sensor in the mix, which even further skews it. Lastly, raising these numbers (right column) effectively puts more fuel into the mix, and helps fudge a fuel injector flow issue here or there.
Neil Emiro
2005 Dodge SRT-4
Page generated in 0.11769 seconds with 13 queries
